  • Tuesday May 14, 2024, 7:43 pm
Last post Author Topic: Software for planning wood bookcases/cabinets/tables etc?  (Read 220104 times)
Re: Software for planning wood bookcases/cabinets/tables etc?
« Reply #275 on: July 28, 2018, 02:29 AM »
Great job :Thmbsup:
« Reply #276 on: July 28, 2018, 08:13 AM »
Speaking of leg position.. Today with my empty cabinet, in order to air it out more, I opened all the drawers fully and the doors...
You can guess what almost happened -- I just caught it in  time as it was about to tip over onto me (!)  :tellme:
I'm not sure having the legs fully forward would have prevented the problem, but it certainly would have helped.  So I may move the legs forward.  Or just remember to load the cabinet up more and not pull out all the drawers at once.
« Reply #277 on: July 28, 2018, 12:02 PM »
Do you have CCTV?  I need videos of you having a panic attack when it happened...for....reasons :')
« Reply #278 on: July 29, 2018, 07:54 PM »
I wondered about that! From the photo it looked as though it could be unstable - the oblong box looked to have too narrow a base to be stable. When I looked at the photo, I initially (mistakenly) thought that you must have had the back of the cabinet screwed to the wall, then I read that the front legs had been recessed and wondered how that was working out. Generally speaking, for stability, narrow cabinets need to have the feet extend outwards, to widen the base of the footprint in the direction of potential fall. Of course, then, people may trip over the extended feet...
Probably simplest to screw the back of the thing into the timber wall studs behind the plaster.
As a standard safety precaution we usually do that anyway with anything in the house which has a narrow footprint (e.g., bookcases), so's they don't fall over too easily in an earth tremor (fairly common in NZ) and squash someone's foot or maim a passing toddler in the process.
« Reply #279 on: July 30, 2018, 10:04 AM »
Truthfully there are virtually no dressers that will not tip over and crush you if you open all of their drawers full of stuff.
You can imagine people with young kids have to worry about such things.
There are special gadgets you can get to hold your furniture to the wall in such cases, and I have a big long office cabinet I bought that has a special mechanism that prevents you from opening both the upper and lower drawers at the same time, just to reduce risk of it tipping over.
Having said that, now that I see that the feet look nice, I will probably move the feet as closer to the front and outside the next chance I get, as I think they look nice, and would make the cabinet somewhat more stable.
« Reply #280 on: March 05, 2019, 03:40 PM »
Decided to DIY remodel my kitchen myself.. New floor already tiled (not fun!!), old counter and sink just removed.. never done kitchen plumbing before... it will be interesting..
« Reply #281 on: March 05, 2019, 06:58 PM »
Plumbing and Electricity are two areas that I personally won't touch.  Good luck!
« Reply #282 on: March 06, 2019, 01:39 PM »
Good Lord! If that's the way your kitchen looks, no wonder you want to remodel.
« Reply #283 on: March 07, 2019, 04:46 PM »
Target
« Reply #284 on: March 07, 2019, 11:18 PM »
rule of thumb, no one should ever touch electricity...
even electricians use that rule...
« Reply #285 on: March 08, 2019, 12:04 AM »
Shocking revelation, that.
« Reply #286 on: March 08, 2019, 12:20 AM »
That lightning wit on display, eh?
« Reply #287 on: March 08, 2019, 08:21 AM »
These kinds of remarks are a bit of a jolt!
« Reply #288 on: March 08, 2019, 08:39 AM »
-cranioscopical (March 08, 2019, 08:21 AM)
Ohm my word, I knew you all wouldn't be able to resist.
« Reply #289 on: March 08, 2019, 09:49 AM »
That comment really Hertz.
« Reply #290 on: March 08, 2019, 02:46 PM »
And so it should! After all, we are discussing the crown joules of mouser's demesne.
« Reply #291 on: March 08, 2019, 04:04 PM »
-cranioscopical (March 08, 2019, 02:46 PM)
I think that there is a potential difference that you re-fuse to see that I can't relay between our alternating current conversations.
« Reply #292 on: March 08, 2019, 08:07 PM »
We're poles apart and, to be direct, at the risk of seeming a growler, that kind of thinking comes close to analog ic. You really should keep an ion it.
Target
« Reply #293 on: March 09, 2019, 08:54 PM »
-cranioscopical (March 08, 2019, 08:07 PM)
come on guys, try to remember this is a DC forum...
« Reply #294 on: March 09, 2019, 09:25 PM »
AC your problem.  ;D
« Reply #295 on: March 10, 2019, 04:39 AM »
AC your problem.  ;D
Un-phased by all of this...
« Reply #296 on: March 10, 2019, 12:45 PM »
AC your problem.  ;D
Trust you to pylon!
Target
« Reply #297 on: March 10, 2019, 06:03 PM »
AC your problem.  ;D
Trust you to pylon!
-cranioscopical (March 10, 2019, 12:45 PM)
pretty sure you guys have ground about as much as you can out of this
« Reply #298 on: March 10, 2019, 07:09 PM »
AC your problem.  ;D
Trust you to pylon!
No one would fault mouser if he set an impedance on the frequency of off-topic conversations on this circuit and placed a demand on us to cut it short.
« Reply #299 on: March 10, 2019, 11:57 PM »
Oops, forgot to quote....
