  • Wednesday May 15, 2024, 1:36 pm
Last post Author Topic: Clipboard Managing-Which one?  (Read 29242 times)
ha14
« on: May 06, 2010, 03:26 AM »
Its not a secret that windows clipboard tool is primitive one for dont support many features such as to retreive older copy/paste, no history in windows. So which one is better to manage in optimum way this exercise.
Re: Clipboard Managing-Which one?
« Reply #1 on: May 06, 2010, 04:48 AM »
The answer to your difficult question may be that this is depending more on the user than on the clipboard. As an example, I have Snagit 9 installed, and it may be the most advanced clipboard you can have, but... I don't use it! It is not to my liking. There may very well not be any "The Best Clipboard" unless you specify your needs very precisely.
Dormouse
« Reply #2 on: May 06, 2010, 04:52 AM »
When I looked, I found ClipMate the best, and I've never seen anything to give me any cause to reconsider.
I found Dittoto be the best free program at the time, and would be very interested to know if anyone thinks there a a better free alternative to it now.
« Reply #3 on: May 06, 2010, 04:53 AM »
Dormouse
« Reply #4 on: May 06, 2010, 04:54 AM »
I also have Snagit, and like it very much. But I don't consider it a clipboard manager as such - I use it for capture and some editing.
ha14
« Reply #5 on: May 06, 2010, 05:27 AM »
What I would like is that it lets to convert from inside clipboard to word, pdf....Also when copy then possible to save in one slot txt+image.
I just found this one
http://www.visualclipboard.com/
TucknDar
« Reply #6 on: May 06, 2010, 05:35 AM »
I've used ArsClip for years.  http://www.joejoesoft.com/cms/showpage.php?cid=97
I used and can recommend ArsClip as well. However these days I prefer DC's own Clipboard Help+Spell:
Deluxe Clipboard Utility that automatically saves a history of text items copied to the clipboard, with tons of configurable options, super easy search, favorites storage, super powerful text modification dialog with preview window.
Perry Mowbray
« Reply #7 on: May 06, 2010, 06:30 AM »
That's crazy Curt!!
I've tried lots of those, but I too have settled for Clipboard Help+Spell... don't use many of the bells and whistles, but the text modification is super handy at times  :Thmbsup:
hpearce
« Reply #8 on: May 06, 2010, 06:34 AM »
I use clipcache pro .... but it is not free
Windows 7 SP1 (TM) Home Premium 64-bit .. Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26 GHz / 2.27 GHz .. 4GB RAM .. NVIDIA GeForce 9800M GTS .. Gateway P-7805u FX
« Reply #9 on: May 06, 2010, 06:35 AM »
I'm personally pretty satisfied with ClipX - simple, unobtrusive, to-the-point, freeware, and suits my needs. Only problem I've had with it is that sometimes OpenOffice locks up if ClipX is enabled and you copy/paste stuff in the spreadsheet app.
ha14
« Reply #10 on: May 06, 2010, 06:35 AM »
While searching I found Global Clipboard
http://www.globalclipboard.com/
Here is more details plus a giveaway
http://www.techishar...l-clipboard-manager/
cyberdiva
« Reply #11 on: May 06, 2010, 09:28 AM »
+1
ChalkTrauma
  • ::41554D::
    • DreamCycle Studios
« Reply #12 on: May 06, 2010, 02:38 PM »
Didn't see anyone mention CLCL yet ( http://www.nakka.com.../clcl/index_eng.html ).. been using it for years..  :Thmbsup:
'Behold! It is not over unknown seas but back over well-known years that your quest must go; back to the bright strange things of infancy and the quick sun-drenched glimpses of magic that old scenes brought to wide young eyes.'
tranglos
« Reply #13 on: May 06, 2010, 02:58 PM »
ClipMate and Ditto are both "clipboard managers" or "extenders", but I think they have very little in common. Someone comfortable with one may find the other unhelpful.
I suppose the free alternative to ClipMate is Mouser's Clipboard Help and Spell. Both are great if you need to categorize your clips, but in my experience the price for this is some encumbrance in accessing individual pieces of text.
Ditto is awesome if you don't care about categories, but just want to bring back previous clips with minimum keypresses (and no mouse). The instant incremental search really shines, especially in that it works transparently with substrings (while ClipMate scans only from the beginning of the string IIRC). It is probably not too helpful with non-textual content, e.g. images, but if you write a lot and use a lot of repetitive phrases, Ditto might be the one to try.
On edit: I only wish someone would recompile Ditto (C++) to remove the networking feature and to enable choosing font for the incremental search display - the text at bottom is entirely too tiny for my 40+ eyes.
« Reply #14 on: May 06, 2010, 03:34 PM »
-ChalkTrauma (May 06, 2010, 02:38 PM)
DC tips and tutorial thread here: [GER/ENG] CLCL Clipboardmanager Forum
I too mostly use ArsClip, but sometimes CHS, and I have licenses for ClipCache Pro and for Clipmate.  It's possible to find an old free version of ClipCache on the Web,  but current versions are payware.
ha14, I think it depends on how many features you want, and how accessible you want them.  Mostly, I only want to retain clipboard history for a while, and have it deleted on FIFO basis.  ArsClip is great because it makes that basic usage easy, while the advanced features are still readily accessible on the rarer occasions I need them.  Some of the others put maybe too much emphasis on the advanced features, rather at the expense of usability of the basic ones.
Not all support things like RTF formatting, so you may have to try several to find one that suits you well.  I see that Visual Clipboard Pro supports Unicode - that isn't universal, either.
« Last Edit: May 06, 2010, 03:43 PM by rjbull »
sajman99
« Reply #15 on: May 06, 2010, 04:15 PM »
+1, same here. 8)
ldarrambide
« Reply #16 on: May 06, 2010, 04:29 PM »
Hi all,
been recently struggling with that problem too, and made an extensive search...
i ended up with two choices, but can't decide myself..
Clipcache from http://www.xrayz.co.uk/
Clipdiary from http://clipdiary.com/
The first as anyway my preference, and is 10% off here: http://www.softcns.c...pcache-pro_9260.html
HTH
cyberdiva
« Reply #17 on: May 06, 2010, 05:22 PM »
This is true for me most of the time, and ClipMate makes this very easy.   But even though most of my use of ClipMate is pretty routine and I don't have many clip collections, I'm glad I can store some Spanish phrases in a separate collection that is easy to access but separate from the rest of my clips.  Also, I value very highly ClipMate's "powerpaste" feature; this permits me to take a bunch of clips and paste them into a document in sequence just by hitting CTL-V.  While ClipMate has many features I don't use, I don't feel that they weigh down the program.  I find it on the whole very responsive and easy to use, while offering me features that I'd miss in a more minimalist program.
« Reply #18 on: May 06, 2010, 05:44 PM »
I'm happy to recommend my own Clipboard Help and Spell, but most clipboard tools do the basic stuff pretty well; i'm finally getting into doing updates for CHS, so if you have feature requests be sure to let me know (on a different thread!).
« Reply #19 on: May 06, 2010, 09:18 PM »
As someone who uses text clips (not images) quite intensively, I can recommend this combination:
  • mouser's CHS Clipboard Help and Spell. This is an excellent text-only clipboard assistant, with some unusual and useful features. Fast and efficient, and also recently updated.
  • hamradio's KK KlipKeeper. Though this partially duplicates CHS' database of clips, it is a handy backup for the paranoid, and it also enables ready access to fast searching of the clips saved, via the FARR search line.
  • The AutoHotKey script in the Quote box below. The script by default gives an unformatted paste on Ctrl+V, and a formatted paste on Shift+Ctrl+V. The formatted paste only works on the last Copy action to the clipboard (I think any older text saved in CHS or KK is saved without its fomatting properties).
; AutoHotkey script -------------------------------------------------------------------
UnformattedPaste:   ; Unformatted paste - Ctrl-V = Remove formatting from Ctrl-V (paste), unless SHIFT key is also pressed.
   ClipSaved := ClipboardAll ;save original clipboard contents
   clipboard = %clipboard% ;remove formatting
   Send ^v ;send the Ctrl+V command
   Clipboard := ClipSaved ;restore the original clipboard contents
   ClipSaved = ;clear the variable
Return
I have also tried these free clipboard utilities, but have not exhaustively trialled/tested them:
  • ArsClip (Very good). Saves images and text.
  • ClipGuru (Very good). Saves images and text, and gives extensive source details for every clip. Has some features not always found in other clipboard assistants. The web site says they have gone away. The last free version I have was v2.8.0, and if you want an installation file for it, you can download it from here.
  • ClipM8 (Very good). Saves images and text. Shareware version includes some image editing functionality!
  • Ditto (Very good). Saves images and text.
Hope this helps or is of use.
UPDATE 2010-12-23: I just found ClipGuru v2.9.0 as at 2010-03-10 on freewarefiles.com.
I have also saved this for people to download from Box.net in case it goes from freewarefiles.com.
« Last Edit: December 22, 2010, 05:46 AM by IainB »
Ampa
  • I am cute ;)
    • MonkeyDash - 2 Player strategy boardgame
« Reply #20 on: May 07, 2010, 03:50 AM »
Since it is relevant to the thread I'll bump an idea which was last raise a year or two ago...
Please Mouser, can we have a way to integrate FARR and CHS?
(Cross link to previous threads asking similar things)
TucknDar
« Reply #21 on: May 07, 2010, 04:26 AM »
Oh yes, please!  :-*
« Reply #22 on: May 07, 2010, 06:38 AM »
Yes!    :Thmbsup:
« Last Edit: May 07, 2010, 06:43 AM by IainB »
« Reply #23 on: May 07, 2010, 06:40 AM »
Quote from: Ampa on Today at 19:50:16
Funnily enough, I was thinking only today that if there were an additional feature that I would like to see in CHS, it would probably be the option/ability to search for a character string using the FARR search box (i.e, same as KlipKeeper).
KK has a useful thing in the shape of the ability to search the klips for a character string using the FARR search box. It's very fast. By comparison, though CHS has more functionality and is pretty sophisticated, I have sometimes found it to be a bit tedious to find an old clip in CHS, whereas it pops up real fast in the KK/FARR search. (e.g., kk +sall string)
+1 vote from me.
tslim
« Reply #24 on: May 08, 2010, 12:12 PM »
For clipboard assistant program, there are 6 features I always want:
1. Combo seek supported (at least for English)
2. Flexible and fully user-definable hotkey (for copy and paste)
3. Unicode aware
4. Spell Checker (English)
5. A seperate favarite clip list (triggered by another user-definable hootkey)
6. Program dependent paste method.
For 1. if I type "test" the highlight bar moves to first item starts with 't' then first item starts with 'te' and it follows.
For 2. [win] key must be supported particularly.
For 3. I normally use 3 different languages (Englisg, Simplified Chinese and another language)
For 4. Something like what is provided by mouser's program
For 5. I mean I can choose a text from the clip list and tag it as a fav item and the fav list is undisturbed by normal copy action but has its own hotkey to bring it up.
For 6. I have program which requires characters to be feed like typing instead of 'paste', I wish I could define a list of program such that when I am pasting a clip, the string is "type" instead of "paste" to them.
If anyone knows a clipboard assitant program that can do all the above, please kindly post it in this thread! Thank you! :P
