  • Thursday May 16, 2024, 12:15 pm
Author Topic: How to manually set clock in Windows 10 Pro?  (Read 3447 times)
« on: October 30, 2020, 07:14 AM »
UK clocks have recently gone back for Daylight Saving time.  My Windows 10 Pro is still showing summer time, not winter time.  I went to Settings > Date & time.  The date is correct.  "Adjust for daylight saving time automatically" was On.  I clicked "Sync now" and had to elevate to Admin (Really?  Just to correct the clock?).  Time server: time.windows.com.  Waited and waited while the little dots trudged around.  Eventually, "Time synchronisation failed."  Tried again with "Adjust for daylight saving time automatically" Off, same result.  Tried again with it On, same again...
Please, is there any way to set the clock MANUALLY?
<rjbull seethes with frustration>
Re: How to manually set clock in Windows 10 Pro?
« Reply #1 on: October 30, 2020, 07:29 AM »
Try changing the time server to something other than Microsoft.
The public servers at NTP.org have always been better for me, for the UK try: uk.pool.ntp.org
The above will round-robin through, currently, 329 NTP servers in the UK, (split 213 IPv4/116 IPv6).
And yes, to change the system time requires admin.
If it still won't sync then the usual culprits: firewall, service, etc, Event log may give more info.
« Last Edit: October 30, 2020, 07:40 AM by 4wd »
« Reply #2 on: October 30, 2020, 09:02 AM »
As far as I know the US (all Windows installations use time server 'time.windows.com') implement DST when winter solstice/summer solstice occur. Most of the rest of the world use the change of seasons to implement DST. There is usually a 2 to 3 weeks difference between these events.
If you think this is already bad, try living in a country where the president decides the DST implementation. Solstices and season changes are more or less set in stone. Randomness introduced by 'el Presidente' is much more frustrating. Believe me.
Anyway, if you have dealings with other continents, better use the NTP servers available for that continent. Since I have set my router to use the time server '0.south-america.pool.ntp.org' and all computers behind it to use the router as their main clock, there is a lot less headache on my end. The 0 in the name of that server indicates stratum 0, the closest you can get to having the same time as the atomic clocks that are spread over the world. A higher stratum number mean that there can be inaccuracies between the time of that server. Also, when you take the time from a stratum 0 server, the inaccuracies of the clock hardware inside your computer/laptop/tablet/phone automatically turns this in a stratum 1 time registration.
For some types of business it is vital to have a stratum as low as possible. Most people don't need to be on the stratum 0 level of accuracy. Which is good, as capacity is limited.
« Reply #3 on: October 30, 2020, 10:04 AM »
Except Australia where we made it easier by just making it the first Sunday in October to the first Sunday in April.
... but only in the southern/eastern states/territories, the northern/western states/territories don't bother with DST at all 😆
« Reply #4 on: October 30, 2020, 01:40 PM »
  • Right-click the clock in the tray.
  • Select "Adjust Date/Time"
  • Deselect "Set Time Automatically"
  • Click "Change" below "Set the date and time manually"
  • Set the time and date to your preference.
  • Click "Change" to confirm your changes.
Date & Time Settings.pngHow to manually set clock in Windows 10 Pro?
Change Date and Time.pngHow to manually set clock in Windows 10 Pro?
Nod5
« Reply #5 on: October 30, 2020, 01:41 PM »
What Deozaan wrote. Or if you prefer the command line, open windows terminal and use the command "time".
https://ss64.com/nt/time.html
x16wda
« Reply #6 on: October 30, 2020, 08:33 PM »
Worth mentioning Dimension4 here.
« Reply #7 on: October 30, 2020, 11:28 PM »
[ Invalid Attachment ]
A change that may be altered back to what the time server at windows.com thinks your clock must be set to. To my knowledge that happens once a day.
Alteration to computer clocks were made by that time server on workstations and servers alike. As you may or may not know, I live in an area where 'el presidente' chooses the moment DST is applied. More often than not that was a different day than what the US or the EU are using for their DST changes.
You think you are irritated by predictable differences between the 2 most common DST systems? Hah! Try mixing a random DST change in, before or after those DST changes. Because sometimes government hated the US, sometimes government was unfriendly with the EU when DST needed to be applied. Politics petty? Damn right it is. Everywhere. And every 6 months a surprise.
How many meetings between employees of us and companies in the EU had to be rescheduled, because of those DST mishaps....
Anyway, Asuncion, the city where I live has its own time zone. To make matters even more fun. You know what truly solved almost all DST problems? Using practically any time server other than the one hiding behind the URL 'time.windows.com'. Yes, the default time server in Windows is the worst NTP time servers around. Seriously, 95% of all my semi-annual DST issues/conflicts went out of the door, by simply adjusting to a time server for the South-Americas. These are maintained by people who take time much more seriously than whoever is in control of the 'time.windows.com' time server.
Changing the clock like the instructions show you here in this thread...that gets old quick if you have to do that daily on every computer under your care for around 2 months a year.
You might think the time server at 'time.windows.com' isn't so bad, but that is only because you live in a time-zone with predictable DST changes. seriously, find out what NTP server is handling time for the continent you live on and use that server instead. After you have done so, I will be the first person you send your Christmas cards to from that moment on...yes, it is that much of a difference.
Look here for your (national/continental) NTP server:
https://www.ntppool.org/en/
As most computers in the world run on Windows, you would think that MS would put competent people to manage 'time.windows.com'. Instead, there are over 4000 different time servers active globally as of this moment. If that is not an indicator the default time server in Windows makes a mess of keeping time...
DST and time zones, from a programmer's perspective:  https://www.youtube..../watch?v=-5wpm-gesOY
Hell....
« Reply #8 on: November 03, 2020, 02:45 PM »
Many thanks, folks! :)
I tried 4wd's advice to change to uk.pool.ntp.org, and so far, after a couple of days, things seem to be OK.  I was annoyed with myself for forgetting TIME in a console, considering how much I did at the command line in the old days: too much windows atrophies your brain...  I've also downloaded Dimension4 against need.  If a Windows update resets to time.windows.com, that's what I'll try next.
