  • Saturday July 5, 2025, 8:04 am
Author Topic: NANY 2018 Release: Dualcopy  (Read 29970 times)
antekgla
    • SRTFilter
« on: October 11, 2017, 10:12 PM »
NANY 2018 Entry Information
Application Name Dualcopy
Version 1.0.0
Short Description A helper app for copy with Teracopy & Fastcopy
Supported OSes Windows (tested in W7 32&64)
Web Page https://dual-copy.blogspot.com/
Download Link https://goo.gl/v7eF54
System RequirementsNone
Version History
  • v. 1.0.0 First Public Release
Author antekgla
Description
Dualcopy is a helper application for copy/move your files with two of the best copy programs for Windows: Teracopy and Fastcopy.
Dualcopy don't have any funcionality by itself. It is a better interface for this two programs, adding Favorites, Recent Used Folders, and Monitoring other apps like Everything, Total Commander, FreeCommander and other.
His main goal is make easy for you to choose a destination for your files.
Features
  •     Favorites menu: Easily configurable only by a text file with a list of your favorite folders. Include submenus for group your favorites as you like.
  •     Recent Used Folder Menu: Dualcopy remember the last folders used and make a menu for easy access. The number of folders in the History is configurable by you.
  •     Pinned folders: You can pin any folder (and folders in your history too) for fast access.
  •     Monitor file managers: Dualcopy can monitor several file managers (Total Commander, FreeCommander  & Windows Explorer) and display that folders like a destination for your copy/move operations. In addition Dualcopy also can display the folder selected in the excellent search engine Everything and any folder o file path copied to the clipboard.
  •     Full Unicode support.
  •     All configurable by a ini file: Dualcopy store all his options in a ini file. So is fully portable.
  •     Windows Shell Extension: for easy access to Dualcopy from any file or folder in your file manager install the Shell Extension (32 or 64 bits). If you dont want to install a shell extension Dualcopy can make a link in the Send To folder automatically.
Planned Features
You have any suggestion? I'm interested.
Screenshots
Main Window
Favorites Menu
Recent Menu
Windows Shell Extension & Send To folder link
Usage
Installation
Portable. Simply unzip the folder anywhere you have write permissions and run from there.
Using the Application
View the F.A.Q in the page program.
Uninstallation
Simply delete the folder with the program. If you have installed the Shell Extension, first Un-install Shell Extension, reboot computer and then delete the folder.
Tips
Install the Shell Extension. Make the program so much easy to launch.
Known Issues
Not what i know.
SRTFilter Automatic Subtitle Editor & Renamer
Dualcopy If you use Teracopy or Fastcopy this can be interesting   - My N.A.N.Y 2018 Entry
« Last Edit: December 13, 2017, 02:45 PM by antekgla »
Re: NANY 2018 Release: Dualcopy
« Reply #1 on: October 13, 2017, 04:41 AM »
Looks good antekgla :up:
antekgla
    • SRTFilter
« Reply #2 on: December 13, 2017, 02:49 PM »
Anyone try this?
« Reply #3 on: December 28, 2017, 03:45 PM »
Anyone try this?
I think it looks great, but I use neither Teracopy nor Fastcopy, so I can't test this out.
antekgla
    • SRTFilter
« Reply #4 on: December 28, 2017, 08:05 PM »
What copy app you use? Or just use plain and simple windows copy?
I strongly recommend Teracopy.
« Reply #5 on: December 29, 2017, 03:20 PM »
My main file manager is Altap Salamander so I use the built-in move/copy manager it has.  I very rarely use regular Windows Explorer.
« Reply #6 on: January 01, 2018, 06:46 AM »
Cross-posting:
Codesector the makers of Teracopy have a promotion of 50% for New Year! through January 7, 2018
New Year Sale – 50% Off/
chashnniel
  • Joined in 2018
« Reply #7 on: October 23, 2018, 02:29 AM »
actually i don't think unicode is supported
i tested the path of teracopy(doesn't work when Chinese in the path, work in English)
this also happen when i edit the fav.txt
« Reply #8 on: October 23, 2018, 04:18 PM »
you should not configure the TXT, but the INI file. It is best to do that from inside the program via the user's graphic interface:
2018-10-23_231216.gifNANY 2018 Release: Dualcopy
Are you using 1.0.0 from "here", or 1.0.1 from his blog, https://dual-copy.bl....com/p/download.html Just maybe they behave differently on this?
« Last Edit: October 23, 2018, 04:36 PM by Curt »
antekgla
    • SRTFilter
« Reply #9 on: March 17, 2019, 02:02 PM »
Tested in 1.0.1 with chinese characters in Teracopy Path and Favorites paths and working OK.
Check if your Text Editor save the Dualcopy.ini and Fav.txt in UTF-8 format.
chashnniel
  • Joined in 2018
« Reply #10 on: March 17, 2019, 09:48 PM »
2antekgla
2Curt
I don't know what happened to that error, and I deleted it since then. Now I test 1.0.1 and it works well.
Thanks :D
« Last Edit: March 17, 2019, 11:22 PM by chashnniel »
Tuxman
« Reply #11 on: July 26, 2022, 09:31 PM »
Does Dualcopy support command-line scripting (e.g. "to move, open dualcopy.exe FileIn FileOut")? I wonder how well it integrates with file managers which do not rely on Windows shell extensions. (Background: After 10 years or so, I installed TeraCopy Pro on one machine again, FastCopy on another, and I can't decide...  ;D)
