  • Sunday May 12, 2024, 4:40 pm
Author Topic: How to search only .exe files?  (Read 4714 times)
david787
« on: January 11, 2018, 03:32 AM »
Possible to make FARR search only .exe files, or .doc, or any other specified file extension?
Re: How to search only .exe files?
« Reply #1 on: January 11, 2018, 03:43 AM »
just add the ".exe" to the search as a separate word, or whatever extension you are looking for.
anandcoral
    • Free Portable Apps
« Reply #2 on: January 11, 2018, 12:23 PM »
Wow ! I never knew I could do that, all these years of using FARR  :Thmbsup:
Do we have a "Like" button for a message ? It would be good as some forums allow to like a message. Also "Bookmark" a message.
Regards,
Anand
« Reply #3 on: January 11, 2018, 12:45 PM »
Under the "Mark Topic" button at the top and bottom of a thread you can bookmark the thread and do other things like this.
anandcoral
« Reply #4 on: January 12, 2018, 11:22 AM »
Thanks. Marked it. But it is not the same as I wished.
I want to mark  a specific message and not the full topic which may have many messages. Also same for bookmark, i.e. a specific message is bookmarked for later perusal.
Anyway, this will do, till we have what I require. One more suggestion is to show text as "Mark Topic .." so that we get the idea it has something more. Now it looks like a button for one job.
Regards,
Anand
« Reply #5 on: January 12, 2018, 11:35 AM »
Regards,
Anand
We'd talked about this before, and the same was suggested.  I think it would require more coding time when other things are more pressing was the response.
