  • Tuesday May 21, 2024, 12:06 pm
Last post Author Topic: winamp 5.5 is fantastic (I thought I'd never say that)  (Read 30920 times)
Re: winamp 5.5 is fantastic (I thought I'd never say that)
« Reply #25 on: December 14, 2007, 12:36 PM »
Yes, somewhere ("File types" or "Display"), there's must be a option where you select if you wish to show Winamp in the taskbar or not. I'm not sure because it's been a while since I used Winamp for the last time :)
« Reply #26 on: December 14, 2007, 12:56 PM »
- a while since the last time you used Wimap, or was "for the last time" intended? One or the other - it has improved a lot.
I will keep looking for the option. Thanks!
« Reply #27 on: December 14, 2007, 01:27 PM »
Yet again the answer was soo easy - all you have to do is to find it...:
"Options > Preferences...> General Preferences > Show Winamp in... > Taskbar / System tray
Well, problem solved.  :up:
« Last Edit: December 14, 2007, 02:12 PM by Curt »
« Reply #28 on: December 14, 2007, 01:29 PM »
A lot of time since I stopped using it, and a while since I tried it for the last time, as I moved to something else. Despite the improvements, I'm not moving back as I don't find nothing enticing in the new version.
Oh, you finally found it, looks they changed the location since previous versions :)
« Last Edit: December 14, 2007, 03:00 PM by Lashiec »
« Reply #29 on: December 14, 2007, 07:54 PM »
I should have told that I found the answer online at Winamp Help:
http://media.winamp..../help/50/Winamp5.htm
WinampHelp.gifwinamp 5.5 is fantastic (I thought I'd never say that)
urlwolf
« Reply #30 on: December 15, 2007, 10:53 AM »
here's what I find winamp 5.5 has over foobar now:
1- autotagging (using cddb, fingerprinting). If foosic worked well, foobar could have something similar.
2- auto album art search (you can get this in winamp calling a 3rd party app, but it's a bit more convoluted).
3- musicIP recommendations (no way in foobar)
4- great album art handling. You can have this in foobar panelsUI, but in my experience the scroll was almost unusable (config: br3tt) and it was a constant waste of time to configure it just right.
5-library autorefresh (foobar 9.5 has this now)
« Reply #31 on: December 22, 2007, 09:13 AM »
[RANT][GRUMBLE]The Canadian dollar has been over 90 cents to the US dollar for the better part of a over a year now and at par since October, and yet DigitalRiver, who handle Wimamp sales, convert the $19.95 US to $27 Canadian for a Pro licence. There is no facility to change currency  :down:. WTF?[/GRUMBLE][/RANT]
Yes, I know, this is what Europeans and particularly Brits have been dealing with for years, but it still rankles  :mad:
« Last Edit: December 22, 2007, 11:17 AM by Darwin »
urlwolf
« Reply #32 on: December 22, 2007, 10:36 AM »
Note: I have gone back to musicIP. Searches are instantaneous there, whereas it takes 2.5 -3 seconds in winamp. The red is eyecandy.
« Reply #33 on: December 22, 2007, 11:20 AM »
Heh, heh - probably just as well that I'm having to hold off, then. I just like to support development. On that note, then, I think I'll explore making a donation to XMPlay, then. It's still my default player and what I use to play individual songs. If it had better playlist support, or at least made that support more convenient to use, I wouldn't be looking any further afield!
« Reply #34 on: December 01, 2010, 10:24 AM »
I got tired with Winamp growing fat and saying AOL all over the place, and removed my PRO version.
Revo counted the left-behinds: 1.783 registry entries and 22 files / folders !!!   :mad:
edited: Winamp was just updated: Winamp 5 Full 5.6.0 Build 3081 Final: http://majorgeeks.co...mp_5_Full_d2490.html Yes, it took 3 years to get from 5.5 to 5.6
« Last Edit: December 02, 2010, 04:13 AM by Curt »
delwoode
« Reply #35 on: December 12, 2010, 01:35 PM »
I still like AIMP(2) , I might give winamp a try if someone can tell me how much memory it uses, maximized
delwoode
« Reply #36 on: December 12, 2010, 02:36 PM »
ok testing it now, sound quality good, uses 32mb and 8.5 mimizimed. Seems good though.
Aimp uses 7mb and less than 3 minimized
« Reply #37 on: December 12, 2010, 03:01 PM »
-amazing, when you think of it. As an example, I have to come to "hate" Ashampoo because of their endless stream of major version upgrades, but Winamp is from another end of the universe: also updated very often, yet merely from 5.5 to 5.6 in 3 years!!! Now THAT is proper value for the money (for a license key)! I'll bet I am going to reinstall my PRO version quite soon! hahaha.
« Last Edit: December 12, 2010, 03:16 PM by Curt »
tslim
« Reply #38 on: December 14, 2010, 11:03 AM »
Just to share my finding and experience:
If you are like me, have a lot of mp3 song collection whose tag info are in multiple languages. (In my case they are English and Chinese Simplified, yours could be different, of course) then this freeware player:
TTPlayer from: http://ttplayer.qianqian.com/index.php
is a must have!!!
1. With few clicks, it can convert tag info of all songs in a folder (sometime I have more than hundred songs in a folder) base on your chosen codepage.  :-*
2. Its lyric search and control feature is so efficient that I can't even think of a better way.
3. It is so easy to extract into individual high quality mp3 files from an APE (with its cue file available).
In brief, every feature I need now and probably in the future is already in the program (that include auto-tagging, tag to file naming etc). I own a MediaMonkey Gold license, but I hardly use it any more due to unicode probelm and I am heavily rely on this free tool nowadays.
The only thing it lacks currently is, it can't really play DTS music file (e.g. some recent WAV file with surround musci effect)...
and
Unfortunately, because it is created by Chinese programmer it has Chinese user interface.
I have not search around for an English version before, may be it is available somewhere out there...
« Last Edit: December 14, 2010, 11:05 AM by tslim »
justice
« Reply #39 on: December 15, 2010, 03:50 AM »
Wish I could see a waveform display of the track like on soundcloud.
