  • Monday May 20, 2024, 7:39 pm
Last post Author Topic: What's your music player of choice?  (Read 107075 times)
JavaJones
  • Review 2.0 Designer
Re: What's your music player of choice?
« Reply #125 on: March 22, 2011, 12:01 PM »
Has anyone tried Banshee? Just found out about it and it looks promising, though I haven't had time to test yet...
- Oshyan
iphigenie
« Reply #126 on: March 22, 2011, 01:53 PM »
I find myself returning to Jriver Media Centre - a lot of stuff works really well especially all the multi node, network setup.
I know there are a lot of criticism about the support but I have never encountered it first hand, and they do give older versions for free which have just about everything that can be needed.
It is mostly a thing of habit, I guess, and the newer version has slowed down tag editing a bit too much
housetier
« Reply #127 on: March 22, 2011, 09:18 PM »
I have, and it has many features I like, many features that are nice. But it also used to crash suddenly, frequently enough to turn me to rhythmbox or mpd (I can't really decide).
JavaJones
« Reply #128 on: March 22, 2011, 09:29 PM »
Good feedback. Do you remember what version (ish) you last used? Rhythmbox is Linux only (I think) so that's out for me. Might still give Banshee a try and see if I have better luck on the crashing front...
- Oshyan
housetier
« Reply #129 on: March 23, 2011, 04:22 AM »
It probably was version 1.6 or 1.7.
Banshee was very delicate with external programs touching media files it had its hands on: deleting, moving, fixing tags, all made it crash but never when I wanted to demonstrate.
Banshee's tag editor had some nice features for mass editing. And you can write scripts that change its album organizing feature, at least one version I had let you do it.
I'd say give it a spin, even though is a bloody fat .net application.
iphigenie
« Reply #130 on: March 23, 2011, 07:49 AM »
That is one of the things I don't want to have in a music manager (or player) - the imposition on the media file structure.
I have noticed many tools want to "import" your files into their own structure. Especially on linux
I have near 100Gb of music, i have spent time ever so slowly cleaning up dupes and badly tagged files, and I have it sync'd between network drives, local drives and USB drives, and I dont want my program to change it all and create DAYS of work for me. Yet so many do.
I encounter that I dont even try the soft.
housetier
« Reply #131 on: March 23, 2011, 10:39 AM »
I have only encountered banshee to do this. None of the other media players I have tried changed files or directories 'behind my back'. I don't remember if you can turn this off.
OTOH if the collection is in really bad shape, a tool like this might actually help sorting the mess.
JavaJones
« Reply #132 on: March 23, 2011, 12:09 PM »
The current Banshee release I'm looking at (called an "Alpha", 1.9.5) has options for whether you want it to reorganize your files. It's *off* by default.
That being said one of my favorite radio stations has a nice AAC stream which I tried first and it didn't play it, so that was a disappointment. I haven't played with it much more, but may do more soon.
- Oshyan
« Reply #133 on: March 23, 2011, 12:17 PM »
What's the stream URL?  I'm curious if Trout can play it.
JavaJones
« Reply #134 on: March 23, 2011, 01:01 PM »
Radio Paradise: http://www.radiopara...iclinks/rp_64aac.m3u
That's for the 64kbit AAC stream, which gives high quality sound without using too much bandwidth (theirs as well as mine).
- Oshyan
« Reply #135 on: March 23, 2011, 01:14 PM »
Which ones on Linux?
I haven't noticed it on Linux any more than Windows, less so in fact.
Or maybe I'm also very turned off by media players that want to play librarian and so I pre-emptively steer clear and thus haven't encountered such.
My media needs are very simple; open this, play that, thank you very much, goodbye til next time.
In that respect, VLC has never done me wrong.
I mourn the loss of Shoutcast access, but I fully understand the reasons why.
No worries, I saved my favorite .pls files long ago and they still play.
« Reply #136 on: March 23, 2011, 02:03 PM »
Cool, Trout plays it fine.  I like AAC streams as well for the reasons you gave.   :D
JavaJones
« Reply #137 on: March 23, 2011, 03:54 PM »
I have to try Trout one of these days. Though I have to admit I'm not one of those "minimal is king" people so I suspect it may not be for me, just as Foobar never was. But it's a damn fine player nonetheless, that much is clear. :)
- Oshyan
« Reply #138 on: March 24, 2011, 01:29 PM »
I'm not the type to toot my own my horn, but I think you'll find that Trout tries to strike a balance between the extremely minimalist players and the completely overstuffed ones.  The one thing that I've tried to maintain from the start is an intuitive load-n-play mentality.  Load files via the menu or drag-n-drop, click the play button and it should just work.  There are sooo many players I have tried that don't do drag-n-drop or even basic multi-file selection; it astounds me at times.   Anyway, enough blathering from me.  If you try Trout and don't like it, you won't hurt my feelings any.   :P
