  • Saturday May 4, 2024, 9:10 pm
Last post Author Topic: Clipboard Help+Spell Extended Clipboard Format Data Discussion Thread  (Read 78179 times)
Re: Clipboard Help+Spell Extended Clipboard Format Data Discussion Thread
« Reply #75 on: February 25, 2020, 01:24 AM »
What hasn't been looked it is do both clips restore correctly when pasted somewhere that is supposed to be able to interpret the data?
they look exactly the same when pasted back in Inkscape.
Here three different (should be identical) clips:
Screenshot - 2020-02-25 , 08_22_51.jpgClipboard Help+Spell Extended Clipboard Format Data Discussion Thread
« Reply #76 on: February 25, 2020, 05:00 PM »
I wonder what would happen if that errant piece that the hash is different on was just excluded?
« Reply #77 on: February 29, 2020, 10:14 PM »
I encountered an issue with the new alpha version after using it for several days where it wasn't updating the clip info as I was adding new clips, and the latest clip wasn't showing in the quick-paste popup menu, and had to restart the program to get it to resume..  Just a heads up.
djMot
  • Joined in 2018
I'm noticing something with this beta.
Although I have "Start with Windows" checked in the settings, it is not.  Frustrating because, after a restart, I'll be going along normally, and merrily cutting and copying away, only to find CHS isn't running and I have nothing but my last clip.
Can you confirm what I'm seeing here Mouser?  Is there something I need to do to fix this or wait for you to do something.
I'm not sure why it wouldn't obey the start at startup, option, but I will check.
I have noticed that the new beta is much SLOWER to start, which I have to check out.
FWIW on windows 7 does start on reboot, but very slow as you say
On another note:
sometimes clips are not pasted properly -- a previous clip is pasted. When I look in the Quick-paste list, the correct clip shows top of the list (and pastes correctly when I select it). Has happened a few times (and I'm not using CHS intensively). Will keep an eye out to see if it happens again and if I notice anything in common with the instances.
Updated with various improvements; support for proper handling of special Metafile data formats. The clipboard format interrogator also now lets you copy single formats to the clipboard -- useful for testing.
I wanted to report that CHS is making duplicate clips from html text copied twice or more e.g. from the forum -- this is resolved with latest release. The clips are recognised as duplicates and only one copy shown on quick-paste list.
:up:
Copying the same vector clip twice is *not* recognised as duplicated clip. When I have some time I will try and look at what you suggest (just copying one format at a time).
My *guess* is that this is because there is some data in one of the formats that is changing -- probably because of a time stamp.
The solution in that case will be some advanced rule to ignore a certain format (or just ignore its hash value).
The trick will be to look at the hash values of the formats in those two vector clips that look identical.  Let me know what you find.
Just uploaded a minor update with new feature in the Clipboard Blob Interrogator: You can now right click on a format and save that one format to a file.  Useful for debugging formats and comparing formats, etc.
I think you'll find when you do that, that the two "seemingly" identical clips actually have some (inconsequential) differences.
« Last Edit: March 09, 2020, 12:42 PM by mouser »
Also, the reason the new CHS was slower for me was that I have the options to backup and optimize the database when the program starts, and with all the large clips this process was taking longer, hence the slower startup times.  I added a tray message to announce when backing up was occurring, and if you have a slow backup you might want to consider disabling the backup on startup function.
The files that are different are the svg files.
Screenshot - 2020-03-09 , 19_32_54.jpgClipboard Help+Spell Extended Clipboard Format Data Discussion Thread
Screenshot - 2020-03-09 , 19_32_58.jpgClipboard Help+Spell Extended Clipboard Format Data Discussion Thread
on the left from folder chs1, right is chs2
Clips look identical when pasted.
This looks to me like Inkscape is titling all 'id numbers' differently. I guess that could be filtered, (please note for me this not so important -- I'm going to save clips occasionally to favourites. Beyond that I wont mind duplicates... Willing to keep checking though if you want: my main machine is down so currently no access to illustrator.
No, that solves that issue.  I think for the most part its no big deal if you get duplicates.
Ideally it would be nice to be able to give CHS a rule like: ignore the hash of a specific format from a specific app.
Uploaded new version which knows how to get image data from the clipboard in more formats.  Try it with your inkscape and see how it does.
You should now see image thumbnails in your quick paste pop up menu and from within the clip grid, etc.
And updated again with a bugfix for image capture.
yes, working well, thanks!
Great  :Thmbsup:
Let me know any bugs or feature requests..
The thing I'm dreading the most is adding some advanced rule system to let people control what formats get ignored..
« Last Edit: March 11, 2020, 12:31 PM by mouser »
But please do let me know if you have any weird behavior.. I need to make sure I didn't break anything before I can put this into wider testing..
Updated so that even folks who have CHS set to only save plaintext, will still use the new url-grabbing feature to record the source url from web page text captures.
FWIW I'm not using it very intensively, but it's doing fine so far
djMot
  • Joined in 2018
FWIW, I'm using it every day, all day.  It's mainly working fine and I think I've resolved the not-starting-with-Windows issue, although I can't explain how.  Might have something to do with multiple versions on the computer (portable beta vs non-portable normal release).  But I did get this error this morning:
2020-03-12_5-07-30.jpgClipboard Help+Spell Extended Clipboard Format Data Discussion Thread
Were you doing anything when the error occurred?
Can you check what version you are running that gave that error, and see if there is anything about the error at the bottom of the Troubleshooting Log page in the options?
djMot
  • Joined in 2018
I don't see anything here that related to the error.  I took the screenshot Thursday March 12, 2020 at 05:07:30 AM.  As I recall, I wasn't doing anything (because I was remoted into the PC that get the error) and was probably doing something on the local machine when it popped up on the remote.
This is the entire log:
::: [ Starting Clipboard Help+Spell v.2.47.17 on Monday March 09, 2020 at 07:07:59 AM ] :::
::: [ Program ends on Wednesday March 11, 2020 at 04:23:20 PM ] :::
::: [ Starting Clipboard Help+Spell v.2.47.17 on Wednesday March 11, 2020 at 04:33:38 PM ] :::
::: [ Starting Clipboard Help+Spell v.2.47.17 on Thursday March 12, 2020 at 11:47:18 AM ] :::
You are using a version somewhat older.. Try installing the latest.
djMot
  • Joined in 2018
Really?  Because I downloaded and installed from the link on page 1 of this thread after reading your post on March 11, 2020, 03:54 PM (6 posts above this one) and there's been no further update announcement.  Is there a more official thread to get beta release notes and links?
