  • Saturday May 11, 2024, 9:37 pm
Last post Author Topic: DONE: Dim the taskbar (set transparency)  (Read 50301 times)
m_s
« on: February 25, 2006, 04:02 PM »
On the back of this entry over on 43F (http://www.43folders...against-distraction/), I would like to find something that would do the same as Merlin's number 2, MenuShade.  I've never liked the Windows' Autohide, but I would love to find something that would quite gracefully fade out the Taskbar and bring it back on mouseover.  On a brief Google search, I turned up about four different things, some free, some cheap.  The one I tried is AlphaXP Lite, and this works really well, but everytime WallpaperMaster changes the wallpaper, AlphaXP seems to forget what it's there for, and the Taskbar is solid again...  Anybody up for coding something elegant and tiny?
The image is from the AlphaXP website, over at: http://www.zeroheros...com/alphaxplite.html
« Last Edit: March 01, 2006, 01:53 AM by brotherS »
Cpilot
    • Bite Notes
Re: Dim the taskbar?
« Reply #1 on: February 25, 2006, 04:56 PM »
Hi m_s.
If your using XP I can do this fairly easily.
As a test copy this script into the edit window here FBSL Studio.
Make sure FBSL.exe is selected then download the exe. onto your machine.
Double click to run and it should fade your TaskBar. run it again to disable.
'$apptype console
#option explicit
#dlldeclare user32.FindWindow,user32.SetLayeredWindowAttributes,user32.GetWindowLong _
user32.SetWindowLong
dim %Ret,%hTaskBar
Const LWA_ALPHA = &H2
Const GWL_EXSTYLE = (-20)
Const WS_EX_LAYERED = &H80000
hTaskBar = FindWindow("Shell_TrayWnd","")
Ret = GetWindowLong(hTaskBar, GWL_EXSTYLE)
SetWindowLong(hTaskBar,GWL_EXSTYLE,Ret + WS_EX_LAYERED)
SetLayeredWindowAttributes(hTaskBar,0,150,LWA_ALPHA)
If it works ok for you and anyone else who wants to test it (WinXP), I'll go ahead and create your application for you.
m_s
« Reply #2 on: February 25, 2006, 05:17 PM »
That looks great!  And what a great site for building apps!  Can you get it to respond to mouseover - i.e. go solid when the mouse hovers?  And can you make the fade a little slower?  And how about setting a variable transparency?  Thanks for your time and effort, Cpilot - much appreciated!
Cpilot
    • Bite Notes
« Reply #3 on: February 25, 2006, 05:26 PM »
-m_s
All those shouldn't be a problem  ;). The little script you tried out only took me about five minutes to whip up.
I'll work on it tonight and provide a link to download. Gives me an opportunity to really work with the taskbar api.  :Thmbsup:
Yup, FBSL can either be installed client side or used server side. It's definately worth a look.
FBSL
Rover
  • Master of Smilies
« Reply #4 on: February 26, 2006, 12:38 AM »
Protest post: not enough traffic on the forums.
Cpilot
    • Bite Notes
« Reply #5 on: February 26, 2006, 01:46 AM »
Protest post to protest post, not enough courage to try something new/different.
As an aside I got about 90% of this little project done....stay tuned.
Cpilot
    • Bite Notes
« Reply #6 on: February 26, 2006, 02:21 AM »
For those who like a preview you can download it here Taskbar.
WinXp only, start the app and mouse over the taskbar and it will become fully opaque, set the transparency with the trackbar and mouse over, it'll become opaque then go to transparency when the mouse is moved off the taskbar.
Close the app window and the taskbar goes back to normal.
I'll finish this puppy up tomorrow.  :Thmbsup:
« Reply #7 on: February 26, 2006, 02:36 AM »
preview release working well here (absent the functions you still have left to implement).  nice work!
Cpilot
    • Bite Notes
« Reply #8 on: February 26, 2006, 02:45 AM »
-mouser
Thanks mouser, just a few tweaks and a little prettyin' up and it'll be ready to roll. As an aside anything behind the taskbar will be visible while the taskbar is transparent.
brotherS
  • Master of Good Ideas
« Reply #9 on: February 26, 2006, 03:07 AM »
WinXp only
Please support Windows 2000 too, when it comes to transparency and stuff both OS are quite similar.
Cpilot
    • Bite Notes
Re: IDEA: Dim the taskbar
« Reply #10 on: February 26, 2006, 03:11 AM »
Try it out brotherS,
according to msdn SetLayeredWindowAttributes is supported in Windows 2000. If it functions ok for you then I'll change the OS requirement.
brotherS
« Reply #11 on: February 26, 2006, 03:15 AM »
Doesn't work here :(
It reloads the taskbar and I see the slider window (can also move the slider), but nothing changes.
Cpilot
    • Bite Notes
« Reply #12 on: February 26, 2006, 03:24 AM »
Go to your system folder and see what version of user32.dll you have, mine is version 5.1.2600.2622. You should be able to download a newer version on the net. That should solve the problem.
According to the msdn documents SetLayeredWindowAttributes should be available for win 2000 and up. If it doesn't work for you then you need to upgrade your user32.dll.
As an aside, It would be very helpful if people with win2000 do try this script and see if it works for them. I would very much like to make the finished product available for as many users as possible.
If some can get it to work and others can't then we'll know it's simply an upgrade problem. If not then I'll dig into some of my old API references and I'll try to come up with an alternative.
Thanks
« Last Edit: February 26, 2006, 03:30 AM by Cpilot »
« Reply #13 on: February 26, 2006, 03:53 AM »
im using winxp btw.
brotherS
« Reply #14 on: February 26, 2006, 05:36 AM »
I'm having 5.0.2195.7032.
But how can I update a system file that Windows is using constantly?
And why was I able to set the transparency with other programs before?
m_s
« Reply #15 on: February 26, 2006, 05:40 AM »
This works well for me, but I have the same problem I had with AlphaXP: whenever WallpaperMaster changes the desktop image, the taskbar returns to solid and stays that way...  Any ideas?
Cpilot
    • Bite Notes
« Reply #16 on: February 26, 2006, 02:38 PM »
-brotherS
Microsoft does it all the time. If the function is not available in your current user32.dll then this script won't work.
-brotherS
I don't know, what programs were they?
-m_s
I'm guessing it's a problem with WallpaperMaster, try setting the taskbar transparent and manually setting wallpapers. The taskbar remains transparent for me no matter how many times I change the background.
brotherS
« Reply #17 on: February 27, 2006, 02:39 AM »
-brotherS
-brotherS
The only one I can remember right now is PS Tray Factory from http://www.pssoftlab.com/
Cpilot
    • Bite Notes
« Reply #18 on: February 27, 2006, 04:16 AM »
Well I'm not sure what method of transparency they were using in their application.
Maybe a little later after I'm done with this one I'll look into the possibility of applying transparency on win2000.
brotherS
« Reply #19 on: February 27, 2006, 04:56 AM »
Thanks, looking forward to that!  :up:
Cpilot
    • Bite Notes
« Reply #20 on: February 27, 2006, 10:23 AM »
You asked for it so here it is. An application to adjust the transparency of the taskbar. WinXP.
Because of the peculiarities of SetLayeredWindowAttributes the script will only allow one instance to run at a time.
There is a read me file...and this app will run in the tray. The icon is a wire frame box. :)
TBFader.
See the to do list.
Enjoy
Cpilot
« Reply #21 on: February 28, 2006, 09:15 AM »
TBFader has been added to the coding snacks page: https://www.donation...dingSnacks/index.php
works great here by the way - nice work!
Cpilot
    • Bite Notes
« Reply #22 on: February 28, 2006, 09:48 AM »
Thanks mouser.   :Thmbsup:
brotherS
« Reply #23 on: February 28, 2006, 11:32 AM »
Drop me a message when I could test the W2k-version :)
skrommel
  • Fastest code in the west
    • 1 Hour Software by skrommel
« Reply #24 on: February 28, 2006, 06:43 PM »
 :) Here's a late entry:
FadingTaskbar
- Change the transparency of the taskbar.
Features:
- Individual transparency settings for when the mouse is inside and outside the taskbar.
- Fade in, fade out.
- Makes the taskbar solid when maximized windows exist.
- Remembers the original transparency.
You'll find the downloads and more info at 1 Hour Software by Skrommel.
Skrommel
« Last Edit: March 02, 2006, 11:03 AM by skrommel »
