  • Tuesday May 14, 2024, 9:32 am
Author Topic: IDEA: Keyboard locale auto-switcher?  (Read 20927 times)
« on: September 01, 2007, 11:08 AM »
[REQ] Keyboard locale auto-switcher?
I don't know if Windows has built-in functionality for this, or if there's perhaps some freeware utility available that does it; if not, I expect it to be a relatively quick hackjob in autohotkey/whatever, if somebody has the time - I'm unfortunately pretty tied up myself :/
Now, for the problem description: I run an English XP with Danish local - no problems there, I can use my quirky æøåÆØÅ letters without having the OS language butchered translated. However, when coding, I prefer an English keyboard layout, because the various chars used in C++ have a better mapping that way.
I have both Danish and English locale installed, and it's as easy as ALT+SHIFT to toggle... but it's annoying that I _have_ to do this every time I start notepad++ or cmd.exe, and ALT+SHIFT can be a bit hard to hit properly sometimes.
So, my idea: automatically setting keyboard locale on application startup. Doable?
« Last Edit: November 14, 2007, 06:10 AM by brotherS »
Re: [REQ] Keyboard locale auto-switcher?
« Reply #1 on: September 01, 2007, 10:35 PM »
another suggestion: why not use a program like AllChars or Skrommels Accents? :)
« Reply #2 on: September 02, 2007, 05:48 AM »
lanux, those apps seem to be intended for inserting special accents... what I really need is the entire key layout to change... a small example: with DK layout, I need to press AltGr+{7,8,9,0} to get the "{[]}" characters - with a US layout I get [] simply by pressing the two keys right of P, and if I hold shift while pressing them, I get {}.
Compare Danish layout to US layout.
« Reply #3 on: September 02, 2007, 08:29 AM »
i see the difference now.. looks simple enough, monitor apps & send some keystrokes.. i will post in a day or two.. :)
« Reply #4 on: September 02, 2007, 11:03 PM »
f0dder, do you want to switch keyboard layout whenever a certain program is active or only upon start? i can basically convert this script to what you want, what do you think?
« Reply #5 on: September 03, 2007, 06:50 AM »
Upon startup is fine, since local settings are stored per process - I can have notepad++ running with english layout and the rest of the system with danish, and when I alt+tab windows itself handles setting the locale.
And there should definitely be API calls to change locale. I just wondered if there was some smart built-in way to do it all automagically :)
« Reply #6 on: September 03, 2007, 10:56 PM »
found a web-site with a list of keyboard language IDs. now to find an API Call that could plugged into AHK to take care of things programmatically.. :)
http://www.cryer.co....ows_locale_table.htm
« Reply #7 on: September 09, 2007, 08:23 AM »
f0dder, try this ahk script: Auto-switch Locale.. :) the script will switch to English keyboard layout whenever certain programs are active.. Start the program once then you can edit the ini file to add more programs - partial windows title will do and also class names in this format: ahk_class <class name>.
btw, i'm not sure how your system is set-up.. so i've configured mine like this (see pic below) and with the assumption that Danish is the default language..
to use with different languages, edit the INI file and add the layout codes in this format: 00000xxx where xxx is the locale code. here are some examples:
00000409
00000401
00000403
00000406
00000407
00000408
0000040B
0000040C
00000410
00000416
00000814
0000040A
English - United States
Arabic - Saudi Arabia
Catalan - Spain
Danish - Denmark
German - Germany
Greek
Finnish - Finland
French - France
Italian - Italy
Portuguese - Brazil
Norwegian – Norway (Nynorsk)
Spanish - Spain (International Sort)
Source: http://www.cryer.co....ows_locale_table.htm
Edit: added the AHK source and Windows locale table.
Edit2: added the recompiled exe (without upx) to avoid false alarms [related thread].
« Last Edit: June 04, 2010, 12:51 AM by lanux128 »
TucknDar
« Reply #8 on: September 09, 2007, 08:33 AM »
mind sharing the source, lanux128?
« Reply #9 on: September 09, 2007, 08:43 AM »
sure, no problems.. i'm planning to post the source after i've finalised things with f0dder as now it's just a quick hack.. but Tuck, if you're in a hurry, you can always PM me.. ;)
TucknDar
« Reply #10 on: September 09, 2007, 09:06 AM »
heh, no hurry, just for "educational" reasons, and scancode reminded me that AHK executables can be decompiled ;)
« Reply #11 on: September 09, 2007, 11:28 AM »
Does seem to work, thank you!
Wonder how 'clean' the solution is... it would be nice if people would generally post AHK scripts in script rather than compiled format, makes it easier to tinker with :)
« Reply #12 on: September 09, 2007, 07:54 PM »
great! that's all i want to hear.. now, i can attach the source as well here.. :)
btw, i've added hotkeys Win+Alt+p & Win+Alt+q to pause and exit the script respectively..
« Reply #13 on: October 09, 2007, 08:46 PM »
found a similar program with the added advantage of changing the typed words to the language intended.. currently supports only 3 languages but you can drop an email to the author to add other languages.
Screenshots
Text Converter
Text Converter will correct typing errors usually happened due to forgetting switch the keyboard language before typing.
Also Text Converter allows you to change letters case from uppercase to lowercase and vice versa or just capitalize the first letter of a word.
http://www.utceditor...v/text_converter.htm
« Reply #14 on: November 10, 2007, 08:02 PM »
I've always had problems with my keyboard changing from French to English -- a real drag when you're using an app like farr and you're trying to get things done quickly.
Anyway : thanks Lanux.  :up:
That little app does exactly what it's supposed to do, and does it well.
« Reply #15 on: November 11, 2007, 07:20 PM »
thanks Armando, i'm glad that you find it useful plus it is very nice to start the day with such a compliment.. :)
PPLandry
    • InfoQube Information manager
« Reply #16 on: November 12, 2007, 09:09 PM »
Many years ago, I got used to the US International keyboard layout. More double-keystoke characters, but it is so complete and matches perfectly with the keycaps. I use it for whatever language I write in (of course, I don't write in Chinease, only in French, English and German)
Real generosity toward the future lies in giving all to the present -- Albert Camus -- www.InfoQube.biz
« Last Edit: November 13, 2007, 12:21 AM by PPLandry »
uuderzo
    • Uderzo Software
Re: IDEA: Keyboard locale auto-switcher?
« Reply #17 on: June 04, 2010, 08:38 AM »
Lanux, thank you for your hint...
I copied from the source of your app and changed this way:
#InstallKeybdHook
ifWinActive, ahk_class Photoshop
è::
SetLayout( 00000409 )
Send, [
SetLayout( 00000410 )
Return
Send, ]
Return
SetLayout(Locale) {
  DllCall("LoadKeyboardLayout", Str, %Locale%, UInt, 257)
Now Photoshop looks like it understands the command, but it does not revert to italian layout after Send command (i love being able to write text with correct keys, you know)... what should I check?
Thank you!
« Reply #18 on: June 04, 2010, 10:39 AM »
try adding a '$' before the hotkey like the code below. i also changed the IfWinActive directive to be controlled by the keystroke instead of the other way around. let me know if this works.. :)
#InstallKeybdHook
$è::
IfWinActive, ahk_class Photoshop
  Send, [
Else
  Send, è
Return
  Send, ]
Else
  Send, +
Return
SetLayout(Locale) {
