  • Tuesday May 7, 2024, 2:01 pm
Last post Author Topic: LATEST VERSION INFO THREAD - ScreenshotCaptor - v4.42.0 beta - July 21, 2022  (Read 1212734 times)
hubi
Re: LATEST VERSION INFO THREAD - ScreenshotCaptor - v4.16.1 - Dec 12, 2015
« Reply #575 on: October 23, 2016, 09:02 PM »
Long time no updates. Any time line when an update is planned etc ?
« Reply #576 on: October 23, 2016, 09:43 PM »
very soon.. ive been up to my eyeballs coding android apps for NANY 2017 but i'm ready to take a break and work on SC and my other windows apps now.
hubi
« Reply #577 on: October 26, 2016, 07:32 AM »
Thanks Mouser.
hubi
« Reply #578 on: February 15, 2017, 10:28 PM »
So here we are in February 2017 and still no updates released.  :(
« Reply #579 on: February 15, 2017, 11:09 PM »
I know my apologies -- I haven't forgotten just been delayed.
IceTater
« Reply #580 on: February 23, 2017, 01:51 PM »
Mouser, would you please consider adding support for high-res monitors in your next version?  I bought a gorgeous 4K monitor, installed Windows 10, and some of the text and border icons are so tiny I need a magnifying glass to read them.  Running in "compatibility mode" does not seem to help.
Thank you very much for the consideration.  There's other screenshot programs out there, but yours has always been all I need and more.  :-)
Tried to attach a screenshot of Screenshot Captor but apparently can't run more than one copy at a time.
« Reply #581 on: February 28, 2017, 09:59 AM »
People are asking for this more and more and it's clear I have to make SC look better for those on 4k monitors.. I have started work on it.
This is true, but SC does have a function to take a screenshot of itself.
IceTater
« Reply #582 on: February 28, 2017, 11:58 AM »
Thank you, Mouser.  Hope you get your own 4K monitor soon!  :-)
Ok I am making some progress on improving SC for use on high-dpi monitors; options look a lot more readable as does text.
Need to do a little more tweaking though for some oddities, and need to scale up the button images.
nitrix-ud
Hope you are making some progress on FARR too !
oblivion
When ordinary coders are sleeping, mouser thunders on, tirelessly adding features to everything, only stopping to worry occasionally if he's doing enough... ;)
-- bests, Tim
I'm afraid lately it's more a case of: Mouser is hibernating and procrastinating and everyone is waiting for some long overdue updates!!
nitrix-ud
Keep up the good work Mouser
We believe in U !  :P
Can I ask that high DPI (4k monitor folks with large text font setting) folks who would be interested in beta testing new versions of SC please contact me, either through forum message or via email ([email protected]).
nitrix-ud
you can send me the beta on my email, i'm not a user of SC but i could try ;)
oblivion
Hey everybody, mouser's human after all!!  :D
Since I'm here... I've foolishly volunteered to put together a presentation that will cover the whole process that resulted in me writing an autohotkey program to plug a few gaps in a bit of commercial software our maternity department uses. ("Foolishly" because my default attitude is to spend as much time as I can working behind the scenes rather than standing up and making a public spectacle of myself. What can I say? I'm British and introverted.)
Er, anyway, so this presentation's going to happen in a lecture theatre (aaargh) and I'm playing with the concept of making a screencast to do most of the work, so I can just do the Q&As and handovers to the other people who had a hand in it.
I have EasyScreenCastRecorder and ScreenshotCaptor and a microphone and, because I enjoy procrastination too and I have until early May, I'm wondering how (or if!) to make ESCR and SC work together and, if I do, if I can mix stills into my screencast (so I can put up screens that I might want to blur bits of) or if I should bite the bullet and learn something completely new.
Any suggestions or advice welcome. I'm currently considering emigrating in order to avoid the whole problem...  :-[
-- bests, Tim
;D ;D ;D
Been there, but eventually never done that drastic measure... :o
oblivion
;D ;D ;D
I suppose I could quit the job too. Or develop a dreadful disease. ;)
-- bests, Tim
High dpi fixes for Screenshot Captor are almost complete....
nitrix-ud
Any advances on FARR regarding high dpi, i'm so impatient to test it !  :P
FARR high-dpi will follow very soon after -- SC is the hard one so once that's working my other apps will be easy.
For those who want to try the high dpi version, let me know how it looks:
https://www.donation...otCaptorPortable.zip
nitrix-ud
That is great news !
FARR will finally enter the 21st century :P
After a quick look on 3000x2000 things now look as they should  :up: :up: :up:. Using that monocle has been a drag.
Looking forward to FARR better things.
FHD 15.6" screen; fonts @125%
(that's not especially high resolution, but SC options dialogue had not adjusted to the 125%)
Before:
Screenshot - 2017-03-05 , 21_32_51.pngLATEST VERSION INFO THREAD - ScreenshotCaptor - v4.42.0 beta - July 21, 2022
which was too small for my eyes...
After:
Screenshot - 2017-03-09 , 21_29_43.pngLATEST VERSION INFO THREAD - ScreenshotCaptor - v4.42.0 beta - July 21, 2022
Options text a lot bigger -- fine for me, still a little smaller than the couple of other apps I looked at.
Tooltips are a good size.
