  • Sunday May 5, 2024, 12:49 pm
Last post Author Topic: Desactivated services and irregular things  (Read 16113 times)
Contro
« on: February 23, 2013, 08:40 PM »
ejem
I would like a software not resident, better portable, to determine if somes services that usually, or predefined, must be running and are stopped or deactivated. And things similar.
Is it possible ?
Best Regards
Re: Desactivated services and irregular things
« Reply #1 on: February 23, 2013, 10:20 PM »
I like ServiWin from NirSoft.
« Reply #2 on: February 24, 2013, 03:02 AM »
How about my latest NANY entry KeepUpApp ?
Oh, to actively monitor anything, the tool needs to be loaded and running, ofc.
« Last Edit: February 24, 2013, 12:22 PM by Ath, Reason: typo in url »
Contro
« Reply #3 on: February 24, 2013, 06:51 AM »
Running to try
I will comment in my poor knowledge
 :-* :P
Contro
« Reply #4 on: February 24, 2013, 08:39 AM »
Oh the first duty :
correct link to KeepUpApp from wonderful Ath
TambiƩn recomiendo su blog Ton a day .
This is good publicity because I know Ath some years ago.
Best Regards
« Reply #5 on: February 24, 2013, 12:24 PM »
The link is fixed, I'll update my blog in the near future, have had a lot on my mind lately...
Contro
« Reply #6 on: February 24, 2013, 01:29 PM »
mmm
I think both programs are for clever people. So better i stay in donation coder. I will ash some doubts .
I suppose I have to read the help of keepUpApp. Seems to add services or applications and knows automatically when are shutdown.
The nirsoft applications seems oriented for prepared people able to decide about services.
So.... I have to ask
 :P
Contro
« Reply #7 on: February 24, 2013, 01:29 PM »
Understood Ath. I am suscribed  :Thmbsup:
« Reply #8 on: February 24, 2013, 01:38 PM »
If you want to check upon a service in irregular intervals and decide to restart it if it's not running, then you can use NirSoft's ServiWin. Run it when you need to do a check, and restart the service that was stopped or paused.
If you need a service (or application) to stay up and running 99.99% of the time, then use KeepUpApp. It will (re)start the service or application, and optionally un-pause a service that gets paused, if you set the corresponding checkbox.
KeepUpApp is not for beginners or computer-illiterates, they usually won't need the functions provided by KeepUpApp.
Contro
« Reply #9 on: February 24, 2013, 01:41 PM »
crcdisk Crcdisk Filter Driver Stopped      Disabled        Normal Pnp Filter DiskBlockVerification Fi...  6.1.7600.16385...   Microsoft Corpora...   MicrosoftĀ® Wind...
udfs udfs Stopped      Disabled        Normal Boot File System UDF File System Driver       6.1.7601.17514...   Microsoft Corpora...   MicrosoftĀ® Wind...    Reads/Writes UD
ws2ifsl
Controlador Winsock IFS
Stopped Disabled
Normal
PNP TDI
Nivel IFS de Winsock2
6.1.7600.16385 ...   Microsoft Corpora...   Sistema operativo ...
What can i do ?
Contro
« Reply #10 on: February 24, 2013, 01:42 PM »
Of course Ath.
serviwin = services.msc
but put in red some items i am investigating with your help
Contro
« Reply #11 on: February 24, 2013, 01:43 PM »
Do you have any services in startupApp. Is for take an idea.
« Reply #12 on: February 24, 2013, 01:45 PM »
Disabled services aren't supposed to run, so they won't start until you enable them from the ServiceManager. But most likely you won't need them?
« Reply #13 on: February 24, 2013, 01:46 PM »
KeepUpApp isn't running as a service yet, but I've been adding that to the ToDo list lately ;)
Contro
« Reply #14 on: February 24, 2013, 02:03 PM »
I don't explain well.
What apps do you control with KeepUpApp ?
« Reply #15 on: February 24, 2013, 02:12 PM »
Any Windows application (32 or 64 bit) or service that you need to stay running for as long as possible, and/or restart when stopped or crashed.
Contro
« Reply #16 on: February 24, 2013, 06:12 PM »
Tell me one I need !!!!!!!!!!1
Contro
« Reply #17 on: February 25, 2013, 10:12 AM »
ath, I will keep-upApp learning.  :P
« Reply #18 on: February 25, 2013, 10:56 AM »
I think what Contro wants is an application that automatically tells him which services are un-necessary and disables them.  I don't think such an app exists because each person/computer has different needs.  Contro, there are many guides on the internet that describe what you want to do.  However, you're going to have to be the one that decides whether or not to turn off a given service.
https://www.google.c...ary+windows+services
Contro
« Reply #19 on: February 25, 2013, 03:05 PM »
i take the link to my database Goldmine
I gonna to learn
Contro
« Reply #20 on: February 25, 2013, 03:10 PM »
Ok McCade
Understood.
Keepupapp adopted
Wonderful thing indeed
Tinman57
« Reply #21 on: February 25, 2013, 08:15 PM »
  You may be talking about something like Fix-it Utilities.  It will automatically disable (if you choose) a bunch of background task and services, plus give you the choice of adding others to the list.  It will set itself to run on every boot-up, but you can remove it from auto-starting.
« Reply #22 on: February 25, 2013, 10:28 PM »
Black Viper's site is what I've used since XP to determine what services I can safely disable.
While YMMV, I've yet to have anything I've disabled due to his info cause any problem on my computers but you do need to know what role your machine has before you go fiddling with them.
And naturally make a backup before you start fiddling.
Contro
« Reply #23 on: February 26, 2013, 07:49 AM »
May be. But not in automation way like Advanced System Care 6
note : I have no knowledge in deep of system care, but the freeware version I don't see the option.
Best Regards
FixIt utilities is a good complementary option to the wonderful KeepUpApp from Ath
Contro
« Reply #24 on: February 26, 2013, 07:50 AM »
Oh my God. i have to take a look
