  • Friday May 3, 2024, 7:04 am
Last post Author Topic: MultiFind Pro 1.7 - file search utility  (Read 32200 times)
Cashper
Re: MultiFind Pro 1.7 - file search utility
« Reply #25 on: February 27, 2010, 05:12 PM »
Great - and please could we have a Favourite Path drop-down as well as path Browse?  Thanks...
I hope that my previous post answered your question. If no, please describe what do you mean by "Favourite Path drop-down as well as path Browse".
« Reply #26 on: February 28, 2010, 02:27 PM »
You can invoke a right-click menu by the "Application" keyboard key (resides between Ctrl and Alt keys on my keyboard).
I didn't know that  :-[  In my case, it's the key between AltGr and right Ctrl.  I think the icon's meant to be a menu.  I always think it looks like a stylised petrol pump  :huh:
What user-defined options should be available in your opinion?
ChoiceEditor works like an extension-sensitive context menu.  You configure your own choices.  In my case, for example, if I have Total Commander's cursor on a .txt file and press F4, I get a menu like the first screenshot.  On the other hand, if the cursor is on a PDF file, I get a menu like the second screen shot.  Some items appear on both menus because I configured them to be available for any extension, "*"
I'm not sure about what do you mean by "send plain filename". But MultiFind Pro already adds several useful command to context menu: "Open File name" and "Copy file name".
I'd like to copy file name only, without path; copy file name with path, as Multi-Find does now; and copy file name with full UNC path.  I don't need the last so much now, but it would have been useful when searching the network at work.
« Last Edit: February 28, 2010, 02:31 PM by rjbull »
« Reply #27 on: February 28, 2010, 02:30 PM »
Yes, that looks like it will fit the bill admirably, thanks.
« Reply #28 on: March 12, 2010, 04:31 PM »
Cashper, maybe I'm missing something again, please can the currently-focussed tab be closed with Control-F4 or Control-W?
The filtering that allows you to search-within-a-search is nice, but please can there be a hotkey to put the cursor in the filter box?  Maybe one that sort of "tabs" between the different filter options, File, Folder, etc.?
Thanks...
« Reply #29 on: April 11, 2010, 11:07 AM »
In case nobody has noticed, MultiFind Pro 1.71 was released on Apr 4, 2010.
sajman99
« Reply #30 on: June 18, 2010, 06:28 PM »
I just now browsed to the MultiFind site and noticed new releases.
MultiFind Pro 1.73 and MultiFind 1.51 are the current versions. Thanks Cashper.
sajman99
« Reply #31 on: July 08, 2010, 01:04 PM »
@Cashper:
I have encountered situations where there's not enough text displayed in the "Matches" tab. Please consider adding an option which would allow the user to add more characters before the found/highlighted text.
Since Curt previously mentioned a spelling error, please allow me to mention that in Options the context menu should read "Integrate MultiFind into Explorer folder's context menu".
Like others have mentioned, I'm also hoping for a portable version.
Thanks very much. :)
Cashper
« Reply #32 on: September 26, 2010, 11:57 AM »
I'm grad to announce that portable version of MultiFind Pro has just been released. It is available on the MultiFind Pro homepage.
Please let me know if you like it.
sajman99
« Reply #33 on: September 26, 2010, 03:36 PM »
...portable version of MultiFind Pro has just been released.
Hi Cashper. IMO MultiFind Pro is a good file search software fairly priced at $24.95 (1-user license). I recently recommended it to a friend who needed to search through many documents.
btw I no longer see any reference to a free version of MultiFind. Have you dropped that feature limited version or does MultiFind Pro revert to the limited MultiFind after the 30 day evaluation period?
Thanks for the portable build. :)
Cashper
« Reply #34 on: September 26, 2010, 05:04 PM »
Hi sajman99,
MultiFind (free version) is not dropped and is updated from time to time, but some features are only present in MultiFind Pro. You can find link to MultiFind on midlinesoft.com, just go to home (root) page.
sajman99
« Reply #35 on: September 26, 2010, 06:00 PM »
Hi sajman99,
Erm...thanks for that clarification. How embarrassing :-[--that's what happens when I rush around posting between football games.  ;D
Thanks for maintaing a free version.
MerleOne
  • 4D thinking
« Reply #36 on: September 27, 2010, 04:48 AM »
BTW, speaking about $$, is there any discount for DC members (sorry if I missed the announcement somewhere) ?
.merle1.
MerleOne
  • 4D thinking
« Reply #37 on: October 11, 2010, 07:43 AM »
About the way searches are specified :
Is there an easy way to look for files that have say 'alpha' and 'beta' in their name.  I would like to locate files having names such as
alpha-20-beta.doc
betaplusalpha.txt
beta.alpha
etc.
.merle1.
steeladept
« Reply #38 on: October 11, 2010, 08:23 AM »
I would think that is what regex expression searches are about, isn't it?
MerleOne
  • 4D thinking
« Reply #39 on: October 11, 2010, 08:37 AM »
For file content, not for file names I think.
.merle1.
Cashper
« Reply #40 on: October 12, 2010, 03:16 PM »
No, currently no discount is available.
alpha-20-beta.doc
betaplusalpha.txt
beta.alpha
etc.
Yes, there is. Enter "alpha;beta" in the "File name" field.
MerleOne
  • 4D thinking
« Reply #41 on: October 12, 2010, 03:28 PM »
Thanks for clarification.
Regarding the 'Alpha' 'Beta' search , I thought alpha;beta was looking for files containing either alpha or beta in their filenames.  Anyway, I'll try it !
.merle1.
MerleOne
  • 4D thinking
« Reply #42 on: October 13, 2010, 04:03 AM »
I confirm : Alpha ; Beta returns all files having either Alpha or Beta in their filename, not what I wanted !
Also, there may be something missing from the latest pro version (1.74) : there is no way to clear the filters except doing it manually.  I wish clear results would also clear the filter, or another button could be required.
Of course I may have missed something, so please don't hesitate to mention it.
.merle1.
