  • Friday May 10, 2024, 5:20 am
Last post Author Topic: NANY 2009 Release: Trout (audio player)  (Read 698906 times)
brotherS
  • Master of Good Ideas
Re: NANY 2009 Release: Trout (audio player)
« Reply #375 on: July 03, 2009, 03:25 AM »
I found a track change-related bug regarding keyboard usage, here's how to reproduce it:
- load/create a list of files to be played
- play a file and hit TAB until the the pause button has focus (press the space bar twice to see if it works)
- now wait for Trout to jump to the next file
- hit the space bar again... and you'll notice that it stopped to work
Thanks again for Trout!
« Reply #376 on: July 03, 2009, 03:55 AM »
It's by design.  What is happening is that, on a track change, the focus is set to the listview (and, consequently, away from the play/pause button).  I did it this way so that you could immediately use the up/down keys to move through the list.
Edit:  brotherS, the easiest way to solve this is to simply add a "Space" local hotkey for the Play/Pause action in the Options dialog.
« Last Edit: July 03, 2009, 04:02 AM by skwire »
« Reply #377 on: July 03, 2009, 03:58 AM »
skwire, how about support for off-line lyrics? if there is a text file with the same filename as the song then it can be displayed in the lyrics windows. would save some bandwidth for someone like me.. :)
Yes, I plan to expand this a bit to include lyrics file reading as well as lyrics tag reading.
brotherS
« Reply #378 on: July 03, 2009, 04:46 AM »
Ah, ok.
Thanks for the suggestion, I did that, and (only after closing and restarting Trout) it seems to work smoothly now! :)
« Reply #379 on: August 11, 2009, 09:24 PM »
* More slight graphical tweaks to the main interface.
-skwire
I seriously hope this is a bug and not how you intended for it to look. I am running 1.0.3.38
Just in case you need it, here is an older screenshot: https://www.donation....msg147257#msg147257
« Last Edit: August 11, 2009, 09:32 PM by app103 »
« Reply #380 on: August 11, 2009, 09:54 PM »
 ;D ;D ;D
« Reply #381 on: August 11, 2009, 10:18 PM »
Hell yes it was.  Sexy, ain't it?   :P
v1.0.3 build 40 - 2009-08-11
    ! Title display coordinates were borked because I can't add ten properly.  (Thanks, app103)
« Last Edit: November 02, 2009, 12:12 PM by skwire »
« Reply #382 on: August 19, 2009, 11:13 AM »
v1.0.3 build 43 - 2009-08-19
    + Added "Enqueue in Trout" shell extension option to the Tools menu.
    * Made the lyrics display window work properly with Unicode lyrics.
« Reply #383 on: August 21, 2009, 12:58 AM »
by page 16 of this thread this shouldn't be a surprise..
from Elite Freeware blog:
"..suggest you give it a chance, i did and now Trout is my main music player. "
http://elitefreeware...-portable-music.html
« Reply #384 on: August 21, 2009, 01:21 AM »
That's very cool.   :D
« Reply #385 on: August 21, 2009, 01:35 PM »
Congratulations, you deserve it.  I'm very impressed with Trout.
« Reply #386 on: August 23, 2009, 12:19 PM »
v1.0.3 build 44 - 2009-08-23
    + Added "Remember list position on start" under Tools, Options, General, Miscellaneous.
      This will make Trout highlight and scroll to the last played row without starting
      playback.  (Thanks, Ice_Tea)
    + Added an "Exit Trout" hotkey action.  (Thanks, Ice_Tea)
« Reply #387 on: September 23, 2009, 07:26 AM »
Trout seems to have stolen the F12 key here
I have a couple of apps that use F12 as a shortcut. When Trout is running, F12 doesnt work in those apps.
(This has been going on a while, I just hadnt made the effort to find out what was causing it)
I just have just four hotkeys in Trout at the moment, none including F12...
« Reply #388 on: September 23, 2009, 07:38 AM »
Ah, crap.  I was adding and testing something and forgot to take it out.  Give me a minute.
« Reply #389 on: September 23, 2009, 07:47 AM »
Thanks and apologies for the trouble.
v1.0.3 build 64 - 2009-09-23
    ! Took out an erroneously left in static hotkey (F12).  (Thanks, tomos)
« Reply #390 on: September 23, 2009, 08:45 AM »
no, Thank YOU skwire :)
troutfan
« Reply #391 on: October 08, 2009, 06:25 AM »
Drag & Drop doesn't work for me.
I have tried all the 3 ways of drag & drop behaviour on Trout settings.
The music files I try to drag & drop from Explorer simply don't get queued on the listing zone.
I already have reinstalled Trout several times. No success.
I'm using Windows Vista Home Premium 32 bits.
Thanks for the support.
« Reply #392 on: October 09, 2009, 03:22 AM »
Hopefully, it's fixed in this build.  Please let me know and thanks for the report.
v1.0.3 build 103 - 2009-10-09
    ! More lyrics box matching and parsing tweaks.
    ! Drag & Drop not working under Vista fixed (?).  (Thanks, troutfan)
« Last Edit: November 02, 2009, 12:13 PM by skwire »
« Reply #393 on: October 09, 2009, 04:05 AM »
Hmmm...if that build doesn't work for you, start Trout directly from the executable file and then try a drag & drop operation.  For some reason, that seems to make d&d work in my Vista VM.  As to why, I haven't a clue.  Maybe some more Vista-savvy folks have an idea?
« Reply #394 on: October 09, 2009, 04:09 AM »
troutfan
« Reply #395 on: October 10, 2009, 10:14 AM »
i got it fixed :)
i installed the latest build and I ran Trout through the installation directory.
the drag & drop function is now working fine.
thanks for the support and keep up with the great work!
troutfan
« Reply #396 on: October 10, 2009, 10:20 AM »
I would also like to make a suggestion for Trout:
Why not create a setting in which the user would choose the place of the dropped files?
I mean, the user should be able to place the files in a specific place (eg.: at the middle of the playslist) instead of the way of getting them dropped automatically to the end of the list.
« Reply #397 on: October 10, 2009, 04:48 PM »
Hmmm...that's not a bad idea.  The only issue would be how to determine where to insert the new rows.  Maybe something like "Insert after highlighted row."  Would something like that be acceptable?
sri
    • Sridhar Katakam
« Reply #398 on: October 14, 2009, 12:18 AM »
Using portable version on XP SP3.
I right clicked on a mp3 and chose to open it with Trout making sure to place a tick in the check box that reads 'Always use the selected program to open this kind of file'.
I opened Trout and it's playing a certain mp3. When I double click on a mp3 in windows explorer, nothing happens.
Any idea?
Here's a screenshot of wassociate for mp3 file extension:
http://img70.imageshack.us/img70/6982/wassociate.png
<a href="https://sridharkatakam.com">My blog</a>
sri
    • Sridhar Katakam
« Reply #399 on: October 14, 2009, 12:39 AM »
I see that the tracks are getting queued in Trout when they are launched from explorer.
So here's a feature request: A option to specify whether files should be queued or played when launched from explorer.
