  • Friday May 3, 2024, 1:24 am
Author Topic: IDEA: clean Taskbar without clock and start button  (Read 12198 times)
apfel
« on: August 18, 2008, 12:29 PM »
Hi, had this idea of a clean taskbar, which only shows the opened windows and tray.
summing-up:
- no start button, but space should be usable
- no clock
- tray should be visible (btw. i use ps tray factory to hide some icons)
- whole taskbar should only be visible, if more than one window is present and on mouseover
hope someone can do this.
apfel.
« Last Edit: August 18, 2008, 12:35 PM by apfel »
TucknDar
Re: IDEA: clean Taskbar without clock and start button
« Reply #1 on: August 18, 2008, 12:47 PM »
Have you looked into alternative shells?
http://en.wikipedia....op_shell_replacement has links to quite a few
Personally I use LiteStep. Note that it can possibly take quite some time to get used to shell replacements and if you want it to behave just like you want, at least LiteStep requires some text file editing. Others, such as bbLean (blackbox for windows essentially) can mostly be configured through menus.
apfel
« Reply #2 on: August 18, 2008, 03:26 PM »
I dont really want a shellreplacement for this.
« Reply #3 on: August 18, 2008, 03:48 PM »
I remember there were thread(s) about removing the Start button, no idea if it was also possible to remove clock too - maybe someone remembers threads or search might produce something!
[edit] of course this
probably wouldnt be covered ...
« Reply #4 on: August 18, 2008, 04:10 PM »
Removing the clock is simpler than one would think :)
Just right-click the taskbar, go to "notification area", and untick the clock! (this is in Vista, but I'm pretty sure it's there in XP too).
VideoInPicture
    • Circle Dock
« Reply #5 on: August 18, 2008, 05:01 PM »
I think I may have a solution....It's 90% there and is based off of an open source project. I'll see if I can make it work.
Author of Circle Dock: http://circledock.wikidot.com
Author of Video In Picture: http://videoinpicture.wikidot.com
Author of Webcam Signature: http://webcamsignature.wikidot.com
Author of Easy Unicode Paster: http://easyunicodepaster.wikidot.com
AndyM
« Reply #6 on: August 18, 2008, 08:20 PM »
LClock , on the "other" tab has a box to "hide Start Button".
http://www.neowin.ne...php?showtopic=157465
« Reply #7 on: August 18, 2008, 08:42 PM »
summing-up:
- no clock
good idea, eventhough currently it can be done separately. e.g. Start Killer can help reclaim the space while the clock can be hidden (see pic). item 4 is quite similar to Skrommel's FadingTaskbar.
apfel
« Reply #8 on: August 19, 2008, 07:09 AM »
Cant use this methode, because of PS Tray Factory. (problems)
AndyM
« Reply #9 on: August 19, 2008, 12:33 PM »
What kind of problems?  I run PS Tray Factory also (couldn't live without it).  Plus I run quite a bit of other stuff.  I'd like to know what problems you had - might be clues for me to figure out some of my system's idiosyncrasies.
apfel
« Reply #10 on: August 21, 2008, 09:53 AM »
LClock relocates the Start Button to hide it and everytime I start PS Tray Factory, the whole tray gets covered by the start butto.
AndyM
« Reply #11 on: August 21, 2008, 02:24 PM »
Ah, I don't hide my start button so I haven't seen that behavior.
« Reply #12 on: August 30, 2008, 11:12 PM »
If you don't feel like going through any taskbar settings to turn off the clock (or just have trouble remembering where it is), I once made a small utility to test some code, that does it. (was never tested on Vista)
http://appsapps.info...oads/removeclock.zip
It may leave a space, but that will go away when one or more icons in the tray refreshes or is added/removed.
As far as the start button goes, I remember some application called TClock2 that might be able to hide/change it. (doesn't work on Vista)
