  • Friday May 3, 2024, 1:58 am
Author Topic: Problem with AHK time stamping  (Read 4740 times)
Attronarch
« on: April 17, 2016, 02:53 AM »
I am using AHK script for text expansion and I've run into some problems with time stamps. Up to now I've been using only one time stamp (date, first one in the code), but after I added two more I messed up everything.
Code excerpt:
:*::date::
FormatTime, CurrentDate,, yyyy-MM-dd ; This is one type of the date format
SendInput, %CurrentDate%
:*::st::
FormatTime, CurrentStartTime,, yyyy-MM-dd    hh:mm:ss ; This is one type of the date format
SendInput, %CurrentStartTime%    START
:*::ft::
FormatTime, CurrentFinishTime,, yyyy-MM-dd    hh:mm:ss ; This is one type of the date format
SendInput, %CurrentFinishTime%    FINISH
They generate:
2016-04-172016-04-17,   09:51:55    START2016-04-17,   09:51:55    FINISH
2016-04-17    09:51:59    START2016-04-17    09:51:59    FINISH
2016-04-17    09:52:01    FINISH
While I would like them to generate:
2016-04-17
What did I do wrong?
Re: Problem with AHK time stamping
« Reply #1 on: April 17, 2016, 08:11 AM »
I would try adding `n to the end of your Sendinputs.  If that does not work try `r`n  for spacing tabs may be useful...  `t
« Reply #2 on: April 17, 2016, 11:07 AM »
Those hotstrings work fine for me in a text editor.  What type of app are you trying to use them within?
Attronarch
« Reply #3 on: April 17, 2016, 11:19 AM »
When I add `n, for :date I get:
2016-04-17
2016-04-17    06:14:10    START
2016-04-17    06:14:10    FINISH
for :ts I get:
2016-04-17    06:14:17    START
2016-04-17    06:14:17    FINISH
For :tf I get:
2016-04-17    06:14:20    FINISH
With `r`n it is the same but with added "enters".
What I would like to get is 2016-04-17 for :date, 2016-04-17    06:14:10    START for :ts, and 2016-04-17    06:14:10    FINISH for :tf.
They do work, but they do not produce results I wanted them to (see above).
« Reply #4 on: April 17, 2016, 11:24 AM »
Ah, I see what you're getting at.  Just add "Return" after each hotstring.
Code: Autohotkey [Select]
  1. :*::date::
  2. FormatTime, CurrentDate,, yyyy-MM-dd ; This is one type of the date format
  3. SendInput, %CurrentDate%
  4. Return
  5.
  6. :*::st::
  7. FormatTime, CurrentStartTime,, yyyy-MM-dd    hh:mm:ss ; This is one type of the date format
  8. SendInput, %CurrentStartTime%    START
  9. Return
  10.
  11. :*::ft::
  12. FormatTime, CurrentFinishTime,, yyyy-MM-dd    hh:mm:ss ; This is one type of the date format
  13. SendInput, %CurrentFinishTime%    FINISH
  14. Return
Attronarch
« Reply #5 on: April 17, 2016, 11:42 AM »
Perfect, thank you very much.
