  • Monday May 20, 2024, 9:27 pm
Last post Author Topic: Scrolling capture is not working  (Read 37560 times)
Techmonkey
Re: Scrolling capture is not working
« Reply #50 on: November 22, 2011, 10:08 PM »
Mouser...thank you for your continued work on this. Scroll capture is really, really, important.  I replaced the exe with the beta. Notepad screen capture seems to work on Win 7 64bit. However, capture in IE 9 does not work at all - areo on. What else can I test to help you?
« Reply #51 on: November 23, 2011, 07:13 AM »
I have figured out exactly how I will do the new scrolling capture -- it's a complete rewrite, but I have everything I need now to code it.  And I think it will exceed everything people are wanting.. I just have to set aside a week or so to code it..
Techmonkey
« Reply #52 on: November 23, 2011, 08:06 PM »
Thanks Mouser. Anything I can test to help please let me know.
« Reply #53 on: November 23, 2011, 08:12 PM »
actually i should collect a list of users who are willing to help test the new scrolling capture.
so anyone willing to help test the new upcoming scrolling capture system, post on this thread saying so.  maybe seeing a list of users will help motivate me.
« Reply #54 on: November 23, 2011, 10:00 PM »
I'd be in to testing it.
« Reply #55 on: November 23, 2011, 11:38 PM »
I'd be happy to if I can. Things are a little hectic for me at the moment but how long could it take?
If you ask him nicely, timns will probably help you out with any lingering font issues.
« Reply #56 on: November 24, 2011, 01:41 AM »
Count me in :up:
« Reply #57 on: November 24, 2011, 02:36 AM »
+1
robinsiebler
« Reply #58 on: December 29, 2011, 12:12 PM »
Scroll Capture is not working for me: When I choose scroll capture, I see it scrolling the window, but when I save the file it only contains the visible region. I am using Windows XP Pro and ScreenCaptor 2.103.01
Happiness is laced with shards of pain
stom2005
« Reply #59 on: January 02, 2012, 12:46 PM »
+1 missing the scrolling feature so ....
splwt
« Reply #60 on: January 07, 2012, 09:29 AM »
it is enough for me.
somebody on this forum uses Snagit now.
thank you with him for this excellent information.
Google is our friend…
Ashers
« Reply #61 on: January 23, 2012, 03:39 PM »
Any news on the new scrolling feature?  Screenshot captor is excellent utility, but the lack of a working scrolling-window capture is real problem for me, and is forcing me to use less user-friendly tools!
I'd be happy to help with the testing.
« Reply #62 on: January 23, 2012, 03:43 PM »
hell yes there is.
i've spent a week full time working on a complete rewrite of the most advanced scrolling capture in existence.  beta test is here:
https://www.donation...ex.php?topic=29550.0
it still has some improvements needed, especially in ease-of-use.
Ashers
« Reply #63 on: January 23, 2012, 03:44 PM »
Sorry, I must have been blind - should have spotted that.  Will give it a go!  Many thanks for all your efforts.
skas
« Reply #64 on: March 24, 2012, 02:55 AM »
As a very long-time registered user of Screenshot Captor, I do remember a time when this feature worked consistently well. But it's been a long, long time since then.
(Btw, as I recall, back when it used to work, it seemed to do more flashing and back-n-forth scrolling than the competing programs like SnagIt. But that was no big deal because it always produced a full image in the end.)
Anyhow, I just tried an auto-scrolling capture of a simple webpage in Firefox 11, and it failed to work on TWO LEVELS:
As I understand it, I'm supposed to press Ctrl+Shift+PrintScreen AND THEN Ctrl+Shift+click.
I definitely remember in the past -- when this feature worked -- the first keyboard command (or tray menu command) resulted in a red-lined frame around the webpage. This appeared with little or no mousing on my part.
But that red-lined frame no longer appears around the webpage. It appears as just redline toward the bottom of the webpage. And if move my mouse toward the system tray, then partially-obscured red instructions appear.
(I tried to get the frame to surround the webpage, by using my mouse like I would for a custom selection screen capture, but it didn't work. And besides, I shouldn't even have to do that. After all, it's a windows object or scrolling capture, so screen capture should know what needs outlining with the red-lined capture frame or box.)
Nonetheless, I thought I'd try the second step: Ctrl+Shift+click.
Thankfully, I'm not susceptible to seizures from strobe lights, or what ensued might very well have triggered convulsions. The flashing was extremely rapid, and it appeared to be both endless and pointless.  Finally, I clicked the escape key, and here, I'm happy to say, the program worked. It stopped attempting the capture.
I was a bit worried I'd have to restart my PC, because the graphics were only partially displayed. But with a bit of minimizing and maximizing of windows, all returned to normal.
Enough said. PLEASE, Mouser, fix this feature. Otherwise people will certainly move to other program for screen captures. And I don't want to do that myself. But at least for now, for scrolling captures, I must do that.
Steve
PS: I was just trying to capture www.abookapart.com -- there's no flash on the page, and nothing fancy at all.  (It was just for a little collection of webpages with exemplary designs or at least some exemplary design elements.)
CLEARLY, the feature fails right at the beginning.
« Reply #65 on: March 24, 2012, 03:00 AM »
Skas, what version of Screenshot Captor are you using?  It sounds like you are still using v2.
There are a series of videos on how to use the completely rewritten scrolling capture feature in version 3 at the bottom of this page.
x16wda
« Reply #66 on: March 24, 2012, 02:30 PM »
FWIW that site captures great in IE9, I just chose a scrolling capture from the menu and followed all the prompts.  I adjusted the left margin out a little and narrowed up the right margin quite a bit (I didn't think keeping the scroll bars in the capture added any value).  I like the prompts, I do a scrolling capture so rarely it's nice to have the reminders...
