  • Friday April 26, 2024, 7:55 am
Author Topic: [SOLVED] Multi Search in the windows registry and options  (Read 4927 times)
Contro
« on: August 16, 2017, 11:54 AM »
I would like to find an utility to search several strings in the windows registry at the same time and list the results.
Best regards
« Last Edit: September 25, 2017, 04:17 PM by Contro »
Re: Multi Search in the windows registry and options
« Reply #1 on: August 16, 2017, 12:11 PM »
Have you googled for anything like that? (Try this link)
Basically non of the available tools has the feature of finding multiple values, unless they would support regular expressions, but these come a lot closer than the standard RegEdit
O&O RegEditor https://www.oo-softw...e.com/en/ooregeditor (free)
RegEditX https://www.dcsoft.c...m/products/regeditx/ (non-free, 30 day trial)
« Reply #2 on: August 16, 2017, 12:18 PM »
Aha, refining my search found me RegAlyzer, and, great for you, it supports Spanish UI language!
With the proper regular expression you van find several terms in one search. (look for round braces for grouping, and the vertical pipe symbol). Or use a logical expression with AND/OR.
« Reply #3 on: August 16, 2017, 12:21 PM »
I use RegScanner by NirSoft and find it easy to use.
http://www.nirsoft.n...tils/regscanner.html
Contro
« Reply #4 on: August 16, 2017, 02:20 PM »
DC is better than googlind !!!!!!!!!!!!!!.
I prefer english to practice.
I found this too : http://registry-finder.com/ . I am not sure admit multiple searchs at the same time.
It's not the first time i am looking for these tools and i trying to recover my "memory".
I remember a program that lets you put part of the key and you go to the key...
a path finder or something i remember.
Or even have favorites (or favourites ?) to go faster.
In 2011 i have a contact with regalyzer, but seems I don't install that time...
I will comment !
Contro
« Reply #5 on: August 16, 2017, 02:22 PM »
I am using !!!!!
« Reply #6 on: August 16, 2017, 05:25 PM »
http://www.resplendence.com/registrar €45 ($48) Resplendence Software, Registrar Registry Manager
award-winning registry management solution with a wealth of powerful features
Features: http://www.resplendence.com/registrar_features
The interface is similar to Windows Explorer. You can use the navigation buttons to browse through the registry. You can use drag & drop or the clipboard to copy and move registry keys
among many many other features:
Advanced Registry Compare
Compare two registry keys with each other in detail. You can compare local registry, remote registries and registry files. Matching and missing items and differences in registry data will be reported in detail.
 Multi-level undo
Registrar supports multi-levl undo. You can undo any changes made to the registry by using the undo feature. Simply press CTRL+Z to undo the latest action or select any previous action from the list that Registrar maintains.
They have a free home version and it is worth the price.... You need the Pro version. Click to enlarge:
2017-08-17_002639.gif[SOLVED] Multi Search in the windows registry and options
« Last Edit: August 16, 2017, 05:32 PM by Curt »
Contro
« Reply #7 on: August 17, 2017, 09:05 AM »
 Multi-level undo
[ Invalid Attachment ]
Nice program indeed Curt. I will test and comment in a near future.
Contro
« Reply #8 on: September 25, 2017, 04:12 PM »
 Multi-level undo
Moz2 - 25_09_2017 , 22_10_50.png[SOLVED] Multi Search in the windows registry and options
Don't like Curt. I try the free version and first execution freeze.
May be my system.
It's not exactly a freeze.
Simply I can't do nothing with the program. I tried twice. I have to finish with the task administrator.
Contro
« Reply #9 on: September 25, 2017, 04:14 PM »
Sorry it was my fault.
After a while a window appear in one of my six monitor. I don't see because the program was running in the monitor 2 and the window appear in monitor 6. It was about configuration.
Now seems to go good.
Best RegardsMoz2 - 25_09_2017 , 22_13_13.png[SOLVED] Multi Search in the windows registry and options
