  • Friday April 26, 2024, 2:23 pm
Author Topic: Download Link Does Not Work for Screenshot Captor  (Read 3477 times)
gproteous
« on: January 26, 2012, 03:02 PM »
I'm trying to download the latest (Nov 13, 2011) Screenshot Captor, and I'm unable to.  On the DonationCenter.com site, on the left, I clicked on the "Download v2.103.01" link, the download started, but after about 22% or 27% it hangs.
Any help please?  Perhaps another site that has this great program?
Thank you
Re: Download Link Does Not Work for Screenshot Captor
« Reply #1 on: January 26, 2012, 03:09 PM »
http://download.cnet...2094_4-10433616.html
Please try this link while mouser finds out why this is happening :)
« Reply #2 on: January 26, 2012, 04:45 PM »
If you're interested, there's also a current beta that seems stable now - he's fixed and hugely improved scrolling capture
Ath, that is a good idea, but my first instinct is to minimize the options and features of that red box window that follows the cursor around, just because i worry about it being confusing.  Let's see if my new version is adequate.
New beta of Screenshot Captor is up that uses the new Scrolling Capture system:
https://www.donation...nshotCaptorSetup.exe
The new system is also used to capture "objects" even when you don't want to do scrolling.
In order to make workflow efficient, instead of the fun introductory dialog that was shown in the first scrolling capture implementation -- now you get the red box right away, and after you select an object you get a dialog.
One improvement in workflow is that it's now easier to understand how to do multiple OBJECT captures in a row -- useful if you want to grab various regions of a window -- and there is natural place for me to add features on window objects -- like adding an option to "capture all children windows", on the post-object-selection dialog.
Let me know what you think!
gproteous
« Reply #3 on: January 27, 2012, 08:31 AM »
Stephen = thank you.  The CNET link you provided worked.  I was able to download.  Just to let Mouser know - the link on the DonationCenter does not work for me.
« Reply #4 on: January 27, 2012, 12:16 PM »
Awesome!
Mouser has been informed of the problem :)
