Can the users of this forum suggest a minimal programming Windows automation solution, which will allow one to perform multiple file opening, clicking, and saving functions.
E.g.: Periodically open CCleaner -> Click Tools - Click "Save to a text file" -> go to a particular folder (create, if non - existent) -> Save as CCleaner Installed App on <computer name> - <current date & time ->.txt.
Thank you for your suggestions.
HAutomating Windows - Fast, easy to use, minimal programming required - solution
The closest you can get might be something like
