Hi mouser. I decided to give Checklist DC a try on my Android phone. What I'd like to do is have a shopping list that includes several stores, such as Safeway, Trader Joe's, etc., or perhaps several lists, one for each store. For each store, I'd like to have a list of things I want to buy. I'd like these things organized into sections, such as Produce, Dairy, Meat, etc. And then under each section, I'd list the things I want. Under produce, I might list tomatoes, butternut squash, grapes, etc.
I tried to set Checklist DC up to handle this, but I got nowhere. I couldn't figure out how to add anything. I could create a category, but that was about it. I had difficulty figuring out whether produce belonged under category or vice versa (esp. since label was in a larger font than category). At no point, could I figure out how to add, say, tomatoes as an item under Produce, which I want to have as a section under Safeway. I'm beginning to suspect that the app simply isn't designed to do this sort of thing. Then again, even more likely it's my mind that isn't designed to follow instructions.
I should note that I found the instructions confusing in at least two ways: they didn't make clear the relationship between label and category (and how those related to item), and they talked about sections, without making clear how sections related to labels or categories.
I'd be most grateful for your help.
I should note that I found the instructions confusing in at least two ways: they didn't make clear the relationship between label and category (and how those related to item), and they talked about sections, without making clear how sections related to labels or categories. I'd be most grateful for your help.
). And the ones that do, like Safeway, would require me to go to the store and make careful notes about what is found in each aisle. That may be more work than I want to do.
