Perhaps I should post this at TheBat! forums but I know we have some active users here so I thought I'd try here first. I received "The Bat!" email client in the April 2018 giveaway (100% happiness!) and I've been using the trial while I wait (and wait...) for my key to be delivered. I'm switching from years of using Claws Mail, and I had a couple questions that maybe someone can help me with.
First, I wonder if there's a way to make IMAP access be "asynchronous" ... I'll explain what I mean. In Claws Mail, when I delete a message it is marked for deletion (shown by a lighter font in the message list), when I move a message it is marked with an arrow, when I mark as spam it gets both. Then when I've marked all the actions I intend to take I hit a button "Execute" and all the moves are made. There is no need for a "Compact" option. In The Bat! (must I always type this exclamation mark?) deleted items are instantly gone, but I keep finding when I visit my webmail page from another computer, for example, that the messages are still there, just marked with strikethrough until I hit "compact". So is there a way to get things the way I'm used to, or can you suggest your workflow for IMAP mail deletion/compaction (i.e. what combination of checkboxes have you chosen in the mail options pages)?
Also, and this might be related, in Claws mail (as I have it configured) highlighting a message (i.e. by deleting the one above, or by using arrow keys on the message list) does not load it automatically - only once the Enter key is pressed or the message clicked on directly is it loaded in the preview pane. Can I do that in The Bat!?
Second, I'm finding the IE-based HTML renderer much better than the built-in one, especially in terms of layout, but there seems to be no way to see the destination of a link. The status bar shows nothing, and while the built-in HTML viewer shows link destinations in a pop-up tooltip, there is no such thing in the IE viewer. This is such a huge security flaw that I won't even consider clicking on a link... am I missing a simple checkbox somewhere to get this information, preferably in a status bar?
I'm still getting my head around the new system so there may be more things I need to ask but these are two that are bugging me for the moment. Thanks in advance!
Eric
EDIT TO ADD:
A couple more questions: First, the "show images" button for the HTML message preview pane appears inconsistently. How can I get that button to always appear?
Second, I'm having trouble getting filtering to work the way I want. As an example, I'd like messages in my "Junk" folder to be deleted after a month. I can either create a filter to do this or set a age limit in the folder settings. But when are filters triggered for existing messages? It seems they only fire when a message is downloaded, or read. And if I set an age limit, the rules can apparently be set run "on exit" which I assume means when exiting the program.... but I never exit the program. My last email client would sit in my taskbar for months until a windows 10 update finally killed it. Claws mail ran filter rules whenever I opened a folder.
Eric
EDIT TO ADD:
