Author Topic: new features  (Read 8,960 times)
tesro
  • Joined in 2017
new features
« on: June 16, 2017, 01:50 PM »
Hi
I am using sCheckbook some time now, and its a great simple programm.  :up: :Thmbsup:
But i was wondering if there is a change to bring some new features in the programm?
It would be great if its possible:
  to translate the programm in other languages
  Select collom to show and hide
  Change the date format
  Auto save every ??minutes
  Import a .csv file to merge 2 .scb files
  The Memo part below the rows to see the hole entry (see attach file/pic)
I hope you understand what i mean, sorry for my bad englisch  :(
    • Superboy Coder
Re: new features
« Reply #1 on: June 17, 2017, 02:22 AM »
Hi, tesro, and welcome to the DonationCoder site.  :)
Not easily done, sorry.
Simply resize any columns you don't want to see to zero width.
You can specify a custom date format as per the following abbreviations: http://www.autohotkey.com/docs/commands/FormatTime.htm ; To set a custom date format, edit the config.ini file and add a "DateFormat" key to the "Settings" section like this:
[Settings]
DateFormat=dd.MM.yyyy
Keep in mind that this feature does not convert previously entered transactions.  Furthermore, not all formats will be properly sortable.  The default, sortable date format is yyyy-MM-dd.
I'll consider adding this.
I doubt I'll add these.  Thank you for your feedback.
Original address: https://www.donationcoder.com/forum/index.php?topic=43963.0
