Author Topic: (urgent) Need AMD/ATI Catalyst Software: CCC 15.7 WHQL - Windows 7 BSOD  (Read 7,411 times)
brotherS
  • Master of Good Ideas
Hello,
I have a nasty BSOD problem with atikmpag.sys (and my Radeon 5650). Windows can only be started in Safe Mode (and a really bad screen resolution), but after spending many hours to look for solutions and trying some of them I'm confident that what I now need is to install the CCC 15.7 WHQL.
Sadly, I can only find version 15.7.1 and that's not fixing the BSOD.
Does anyone here have better search skills or the version 15.7 installer still on their HD?
Thank you.
If they did a .1 fix they probably pulled the previous driver from their download page.  I would try the Wayback Machine Web Archive
If this was an update that went bad, try doing a driver rollback with Device Manager.
brotherS
Wayback didn't help and rolling back (sadly) wasn't an option, but I now contacted the AMD support. They pointed me to the 15.7 version (http://support.amd.com/en-us/download/desktop/legacy/previous/detail?product=legacy3&os=Windows%207%20-%2064&rev=15.7). Fingers crossed!
Thank you.
Cool.  Good luck with it.  :Thmbsup:
dr_andus
brotherS, I feel your pain. Let us know how you get on.
brotherS
@dr_andus: yeah, that sucks...
Turned out the AMD gfx card had developed a hardware issue, and since my Vaio model didn't allow to replace it, it was time for a new PC.  :down:
I decided to buy an Acer, and am just in the process of installing everything. I love how quiet it is!  :up:
Thank you.
Original address: https://www.donationcoder.com/forum/index.php?topic=43165.0
