Author Topic: [Bug] Menu displaying  (Read 11,984 times)
anatabai
« on: December 15, 2012, 09:26 PM »
I experience a bug displaying the menu (Windows 7 Pro x64, SP1): Show the menu, move the mouse and then show the menu again. The menu at the old location will remain.
Here is a screenshot:
« Last Edit: December 15, 2012, 09:31 PM by anatabai »
Re: [Bug] Menu displaying
« Reply #1 on: December 16, 2012, 05:14 PM »
Yikes, that's unpleasant!  Doesn't seem to happen here but I need to try it on win 7 and see if i can reproduce.
« Reply #2 on: December 16, 2012, 06:01 PM »
FWIW, not happening here with exactly same OS details "(Windows 7 Pro x64, SP1)"
anatabai
« Reply #3 on: December 17, 2012, 10:59 AM »
Some more details: CHS v2.17.1.0 (portable)
Maybe it has something to do with the video card?
I attached a video clip showing this behavior.
« Last Edit: December 17, 2012, 11:22 AM by anatabai »
« Reply #4 on: December 17, 2012, 11:02 AM »
Does it happen with right-click too or just left-click?  Does it happen with any other programs?
Do the old menus that are shown actually "work" -- that is, can you click items on them? Or are they just graphics artifacts left on screen?
anatabai
« Reply #5 on: December 17, 2012, 11:34 AM »
I don't click any mouse button. I press the hotkey for the menu, move the mouse and press the hotkey again, move the mouse again and so on.
This bug occurs in Notepad++, Notepad, WordPad, Word, Firefox,... seems to occur in every program.
The old menus are not clickable, but strangely they react to the hotkey for showing/hiding the menu.
« Reply #6 on: December 17, 2012, 11:44 AM »
Ah I understand now!
You are repeatedly pressing the HOTKEY to show the quick paste menu.. I thought you were bringing up the tray icon menu.
Ok I can reproduce this now.  I will fix -- though it's not really a problem per se, it is disconcerting.
anatabai
« Reply #7 on: December 17, 2012, 12:08 PM »
OK, thank you! :)
oblivion
« Reply #8 on: January 10, 2013, 12:12 AM »
The tray icon menu is another thing. On my Vista system, if I right-click on the tray icon the menu appears briefly where I'd expect -- above the notification area -- then leaps up 1/3 of the screen so it's approximately vertically centred. It's been doing it for a while, it's most disconcerting, but it doesn't do it on the XP or 7 machines I use. Have I set an obscure option that I shouldn't have? I don't think this USED to happen... :huh:
-- bests, Tim
« Reply #9 on: January 12, 2013, 09:28 PM »
Strange.. anyone else notice this?
JeremyWW
« Reply #10 on: January 17, 2013, 11:26 AM »
I can reproduce this. Win 7 Pro x64.
« Reply #11 on: January 25, 2013, 02:41 AM »
Left-clicking does not produce same bug as right-click?
oblivion
« Reply #12 on: January 25, 2013, 06:46 AM »
No. The menu is positioned just above the taskbar as it should be.
-- bests, Tim
Original address: https://www.donationcoder.com/forum/index.php?topic=33298.0
