Thanks Carol
You're welcome
I am a little ways yet from being setup yet. I see that i will have research as i go. Any other tips on setting up a computer for video editing
I am not the best person to advise because I don't follow my own advice ... but ...
Generally for audio and Video editing the perceived wisdom is to have a separate installation altogether (preferably a dedicated computer).
If that isn't possible, then a separate Windows installation is a good way to have clean system to work on. By that I mean have a dual boot system.
With Windows 2000/XP this is dead easy as multipboot support is there 'out of the box'. Just create a second partition using a suitable partitioning tool (such as partition Magic) alongside your existing windows installtion, and run Windows installation. when given the oppotunity during the install elect to choose the location of the installation and point at your new partition. Go through the whol process and next time you start up you will have a menu of which version of windows to boot up into.
Second part of this is to remove as much crud from standard windows as you can get away with (look for windows optimization tips on the web - particularly which services and processes can be safely disabled) and use the fastest drivers you can find, esp. for graphics and audio.
This negates you first post as you now have a dedicated platform for audio and video production but it will work a lot more efficiently.
For Video/Audio work it is also worth tweaking your system further ... move your page file to a separate hard disc, and if your applications need a scratch working folder if at all possible put that on a third hard disc. It is good if you can have a dedicated scratch disc that can be regularly formated. Ensure that compression and indexing are switched off on all drives too.
If all this is too much you can compromise by installing on your normal working Windows installation but things will run slower and you may suffer glitches - especially when previewing edits. Best thing here is to try and keep your scratch work area off the windows partition on a separate disc (preferably dedicated). If you can't afford dedicated disc then ensure you get a good defragmenter (such as Perfect Disc) and defragment your discs regularly, esp. before you start doing Audio/Vidoe work. Also be conscientious about clearing rubbish off your hard disc - it is amazing how quickly even large hard discs fill up with crap when you are dealing with large AV files).
I see that you have had fun in my expansive country. I live on Vancouver Island on the west coast.....Garnet.
Yes, my parents live in Ontaro and I have had a few good trips including some excellent canoe trips. Ontario is canoe heaven as far as I am concerned. I am no longer bothered about doing too much white water, but I really enjoy being able to get out in the wilderness for a few days with just a paddle and a tent for company ... (not to mention the bears!)
I'd really love to get over to BC and the Rockies, and one of these years I want to get to the ski areas (particularly Fernie).
However, the place I would really like to visit is the Mount Elias Range, up near the Alaskan border - but I have to accept I am probably getting too long in the teeth to be able to cope in such a wild and inhospitable environment these days. The thought of waiting days on end for good enough weather for a light aircraft to get in, and then waiting even longer to get out is probably more for the young! I can still dream though ...
