Basic Action Scripting |
Top Previous Next |
The Action Script list (in the Options Dialog) consists of a single TEST followed by 3 pipe characters (|||) followed by an action string, and then optionally additional ||| separated action strings.
For example: IMAGE ||| MSG hello
Or for example: VIDEO ||| MSG hello there ||| MSG goodbye
A more realistic example using the helper tools: IMAGE ||| %dowatermark% ||| %doemail%
You can temporarily disable any line by preceding it with // to mark it as "commented out", which will cause the program to ignore it.
The TEST part can be used to restrict the actions to files of a certain file extension. You can specify:
When a TEST matches, all of the action strings following it will be "queued" up for execution, in order. If any of those actions should fail, all of the action strings will be placed into the "failed" buffer, where they can be re-queued for a later re-attempt.
