  • Monday September 21, 2026, 3:45 am
Last post Author Topic: Release: sStockQuote  (Read 101122 times)
« on: April 14, 2013, 12:05 PM »
TitlesStockQuote
DescriptionA simple stock quote application with CSV export.
Supported OSWindows 7.  Probably works, but not tested, on Windows XP/Vista/8
Website:http://skwire.dcmembers.com/fp/?page=sstockquote
HistoryChangelog
DownloadsStockQuote.zip
PAD filepad.xml
Screenshot2014-03-18_154857.pngRelease: sStockQuote
« Last Edit: October 21, 2014, 01:21 AM by skwire »
Re: Release: sStockQuote
« Reply #1 on: April 14, 2013, 04:56 PM »
I have no money to invest in the stock market but I think this looks beautiful and elegant and i'm sure it will hit just the spot for some  :Thmbsup:
« Reply #2 on: April 14, 2013, 05:57 PM »
Oddly enough, I don't know the first thing about trading stocks and such.  I just like to track and compare the stock prices of a few companies.  =]
« Reply #3 on: April 14, 2013, 06:01 PM »
I predict lots of feature requests..
PhilB66
« Reply #4 on: April 14, 2013, 06:11 PM »
Is it for end of day or 15-minute delayed quotes?
« Reply #5 on: April 14, 2013, 08:14 PM »
I foresee this as well but I want to keep it very simple and very clean.  There are many more advanced and complex applications in this field and I've really no desire to re-invent the wheel.
I think it's the end-of-day quote as the description is "Last trade."  Again, I'm no stock expert by any means.
« Reply #6 on: April 15, 2013, 09:41 AM »
« Reply #7 on: April 15, 2013, 09:48 AM »
That was quick!
« Reply #8 on: April 15, 2013, 10:55 AM »
Featured on ghacks.
Thanks for the heads up, cmpm.  New update here:
Website | Download
v1.0.1 - 2013-04-15
    + Added option to load stock data on startup.
    + Added Ctrl+R and F5 hotkeys to fetch stock data.
    * Rearranged the date format to yyyy-mm-dd.
« Reply #9 on: April 17, 2013, 09:46 PM »
you are certainly welcome skwire
sStockQuote is getting around fast!
http://www.snapfiles...get/sstockquote.html
nkormanik
« Reply #10 on: May 28, 2013, 11:41 PM »
Thanks Skwire for this handy little program.
Will be interesting to follow what sort of "enhancement requests" it generates.
-- Probably the first would be "auto-update" -- one minute, five minute, etc.
-- Add in some additional available fields.  Open, high, low, close, volume.
-- Another really useful one -- and may not presently exist out there; for sure not free -- would be creation of a log file for some particular security.  With ability to bring the log file into Excel, etc.  One could easily then see the daily trend, or two days, or however much data the log file holds.
The above item would be particularly good for specific options prices, as that data tends to disappear and is not retrievable anywhere.
Nicholas Kormanik
« Reply #11 on: May 29, 2013, 11:57 AM »
You're welcome.
I've considered adding this but the "add alerts" feature requests will come next and I really don't want to deal with that.
Ah, crap.  :-[  I forgot to upload v1.0.2 which adds an additional tab with many more data fields.  I've uploaded it now so please check it out.
I think you can get this type of historical data from the Yahoo Finance page.  Again, though, what I know regarding the stock market wouldn't fill a thimble so I might be (read: probably am) wrong.
Website | Download
v1.0.2 - 2013-05-29
    + Added new tab with more comprehensive data set.  (Thanks, P. Loshuk)
    + Added "Yahoo! Finance lookup" to the Edit/context menu.  (Thanks, P. Loshuk)
    + Pressing Enter now performs a Yahoo! Finance site lookup.  (Thanks, P. Loshuk)
« Reply #12 on: August 04, 2013, 11:27 AM »
Website | Download
v1.0.3 - 2013-08-04
    + Added simple alerting system.
    + Added minimise on startup option.  (Thanks, P. Alby)
    + Added close to tray option.  (Thanks, P. Alby)
    + Added minimise to tray option.  (Thanks, P. Alby)
    + Added start with Windows option.  (Thanks, P. Alby)
nkormanik
« Reply #13 on: August 04, 2013, 03:22 PM »
Getting better all the time....
« Reply #14 on: November 08, 2013, 11:21 PM »
Website | Download
v1.0.4 - 2013-11-08
    + Added "Growl for Windows" support.  http://www.growlforwindows.com
    + Added balloon tip option for notifications.
    - Removed native popup support.
nkormanik
« Reply #15 on: November 11, 2013, 07:56 PM »
Wow, Skwire.  Better and better.  May turn out to be a tool many can use.
pstein
« Reply #16 on: December 04, 2013, 01:14 AM »
I just found the sStockQuote tool and I like it.
However I miss some important features:
1.) I prefer not to have two tabs "Stocks" and "Stocks (extended)" but only one tab where I can select the columns (by checks in a drop down menu" or by checkboxes in a settings dialog.
2.) I miss a couple of columns:
- number of shares
- buy date
- win/loss amount since previous day close
- win/loss since buy date
- buy price
- position amount (=current price * number of shares)
Could you add these features and columns in the next release?
Thank you
Peter
« Reply #17 on: December 04, 2013, 11:48 AM »
Thanks for trying it out.
I agree with you and admit that I took the easy way out.  The problem with GUIs is that, sometimes, coding the user options takes ten times as much work as coding the actual applications general purpose.
- number of shares
- buy date
- buy price
sStockQuote gets its data using the method found here: http://www.gummy-stuff.org/Yahoo-data.htm
As I mentioned previously in the thread, I'm no stock expert by any stretch so, if you can, please correlate the data parts you want with the codes in that table and let me know.
pstein
« Reply #18 on: December 05, 2013, 03:48 AM »
- number of shares
- buy date
- buy price
Well, currently sStockQuote is just something like a Ticker+Price tool.
Why not extending it to a full (or at least advanced) portfolio management tool?
The values I listed above cannot be retrieved from Yahoo but must be entered by the user.
Example: When the user bought 1000 Amazon shares then he enters this value in a new dialog window.
Together with the last price information sStockQuote gets from Yahoo he can get an overview about the absolut change in money units.
Peter
« Reply #19 on: December 05, 2013, 10:26 AM »
That was my original intention in writing this app.
A few reasons:
  • See above.  The original intent of the app was a quick way to check multiple stock prices.
  • It seems there are plenty of applications already out there that do portfolio management.  No need to reinvent the wheel.
  • I simply don't follow the stock market enough to care about portfolio management.
mthadley
  • Joined in 2014
« Reply #20 on: January 31, 2014, 12:33 PM »
Great little stock tracking app!!
Would be terrific if the Market Capitalization column (extended tab) took into account M (million) vs B (billion) when sorting
Would also be helpful to show currency (for stocks on non-US markets)
« Reply #21 on: January 31, 2014, 03:42 PM »
Hi mthadley, and welcome to the DonationCoder site.   :)
I've tried all the sort options available to me and, not suprisingly, none of them will sort that way.
As I mentioned before, I know very little about the stock market so I'm not quite sure what you're asking for.  sStockQuote gets its data using the method found here: http://www.gummy-stu...f.org/Yahoo-data.htm.  If you can correlate the data bits you want with the codes in that table, let me know, and I'll see what I can do.
« Reply #22 on: January 31, 2014, 04:13 PM »
This is awesome.  But don't let bloomberg hear about this!
« Reply #23 on: January 31, 2014, 04:23 PM »
Thanks much, superboy.  Based on how little sStockQuote actually does in terms of stocks and portfolio stuff, I'm rather surprised by the amount of positive feedback that it gets.  I mean, is there really a derth of apps that do what sStockQuote does?  I'd like to think there are many, much more capable stock apps out there.  Again, I know jack squat about stocks and the stock market so it's an honest question.
« Reply #24 on: January 31, 2014, 09:23 PM »
My opinion...it's more of a case of the people that would really use this are the kind of people that would have no problem throwing a ton of money for the bloomberg machines.  It's an industry with a lot of confidentiality, lots of specialized (expensive) software, etc.  They don't really care about the fact that their hardware/software is more expensive than it should be.  And most of the people using it are not tech geeks at all and doing their best to keep up with the competition.
But the bloomberg machines are just regular computers with a custom colorful keyboard and the special bloomberg software.  you can't buy them, you can only rent them for $5000 a month.  It's the most genius business plan i have ever seen.  If their software was for sale, you can easily just buy a regular computer, install their software, and it would be the same thing...maybe buy one of those keyboards with the led keys you can customize to your liking.
But times are a changing...i wonder if software like yours might be useful for really tiny shops ( a few people handling small portfolios) that wouldn't be able to justify bloomberg machines.  i can see that happening.  It's actually an interesting idea, i'd like to run it past one of my hedge fund buddies.
