Commandline Arguements
Top  Previous  Next
You can invoke the program with commandline arguements.  If the program is already running, the already running instance will be passed the commandline arguements, and the 2nd instance will be immediately exited.
•-show
Show the form if minimized
•-hide
Hide the form if showing
•-exit
Exit the program (all instances)
•-pause
Pause the processing queue
•-unpause
Unpause the processing queue
•-queue ["filepath"]+
Add one or more files to the processing queue (for example: -queue "c:\Screenshots\image1.jpg" "c:\Screenshots\image2.jpg")
•-qaction action string
Add a single action lines to the processing queue (for example: -qaction run C:\uploaders\upload.exe ''c:\Screenshot Directory\image1.jpg'')
Important note: because you cannot easily pass double quotes (") on the commandline, you can use two single apostrophes which will be converted to double quotes.  Everything following the -qaction paramter will be added as an action.
