  • Tuesday April 23, 2024, 5:01 am
Author Topic: New FARR user here, my view on some odd behaviours  (Read 7672 times)
bertuslakkis
  • Joined in 2015
« on: April 20, 2015, 09:59 AM »
Hey guys, I've used Launchy for over 4 years now but new bugs kept cropping up, like not being able to close it or crashes.
FARR has really impressed me so far, for example I love the regex support. I'm really glad I found it!
Although there are some shortcomings and/or possible bugs I've noticed:
There's only one undo level in the search bar, I'd like to have more as a default, something like 25 or even 50 (or optimally an amount that can be configured).
Ctrl + Shift + arrow keys doesn't select words, it just changes the position to the previous/next words, so it's ignoring the shift key in this case.
Ctrl + # to launch any numbered search results while FARR stays open doesn't work correctly for me:
when setting Window Options - Focus Preservation to
- Ignore, doesn't work because it focusses my Firefox window after launching, negates the stay-open functionality
- Always Maintain Focus, works
- Regain Focus Only After Launching Apps, doesn't work for firefox searches? (apps and regex matches are different probably?)
- Hide When Focus is Lost, doesn't work as it focusses the Firefox window after launching, negates the stay-open functionality
The problem seems to be related to always focussing the firefox window after a launch, no matter what hotkey combination is pressed.
My desired functionality is as follows:
setting Window Options -> Focus Preservation to Hide When Focus is Lost
pressing Alt + # to launch a search result, hides FARR, and focusses the associated application it launches
pressing Ctrl + # to launch a search result, leaves FARR open, and doesn't focus the associated application
Further information: I toggle FARR with the Alt+Space hotkey, and it auto selects any previous search text.
I installed the FCalc plugin for basic quick calculations.
Which has the annoyance that when I press enter to copy the result to clipboard, it automatically types the alias "fc " again in the textfield.
Is this something I can change via settings or can only the plugin author change behavior like that?
I hope I've explained things well enough.
Thanks in advance!
« Last Edit: April 20, 2015, 10:49 AM by bertuslakkis »
phitsc
Re: New FARR user :)
« Reply #1 on: April 20, 2015, 10:21 AM »
Concerning Ctrl + Shift not selecting words: this seems to be a deliberate choice and was also discussed here https://www.donation...ex.php?topic=27154.0 (a long time ago)
It still confuses me every now and then :huh:
Never noticed that FARR has undo though :)
« Reply #2 on: April 20, 2015, 10:45 AM »
Oops i don't think it was a deliberate choice, just snuck past me.. I'll look into it again...
Welcome, bertuslakkis  :up:
I'll look into multiple level undo as well.  ps. a good useful tip is Ctrl+Up and Ctrl+Down to scroll through past search history (or type: historys).
fcalc: yeah i'm afraid that is part of fcalc to reset search to fc.
ok it sounds like i should be able to fix the stay open/focus issue by having ctrl+# behave as if "Always Maintain Focus" option is set, yeah?
bertuslakkis
  • Joined in 2015
Re: New FARR user here, my view on some odd behaviours
« Reply #3 on: April 20, 2015, 10:58 AM »
Hey mouser and phitsc, thanks for your answer, exactly what I wanted to hear!  8)
Yes, this would be the perfect solution for me :Thmbsup:
« Reply #4 on: April 21, 2015, 07:42 PM »
Ok I've attempted to add this, will be in next beta upload.
bertuslakkis
  • Joined in 2015
« Reply #5 on: April 25, 2015, 08:26 AM »
I just tried the new beta, and it works as you described, perfect thanks!
I'll be looking forward to the other suggestions in upcoming beta's :)
bertuslakkis
  • Joined in 2015
« Reply #6 on: October 02, 2015, 12:31 PM »
Hey there mouser, I know you've been very busy with the forum/site upgrade.
But I was wondering if there's any update on my suggestions from my original post :-[
« Reply #7 on: October 14, 2015, 12:02 PM »
+1...
especially concerning the Ctrl+Shift+arrows (left-right) for selecting. Thanks!
