Special Predefined Variables |
Top Previous Next |
FARR has a few predefined special variables you can use to perform advanced configuration. If you wish to use these variables, you should define them under the [PredefinedVars] section of the User Variables, as follows:
AliasDirs - Use this variable to add additional custom folders to scan for alias files. Separate multiple paths with | character.
CustomSearchIniFiles - Use this variable to add additional custom files that contain lists of search folders, in the same format as the normal FindAndRunRobot.ini file. Separate multiple file paths with | character.
Examples:
[PredefinedVars] AliasDirs=C:\MyDocs\MyCustomAliases | E:\MyDropBox\MyFarrAliases CustomSearchIniFiles = C:\MyDocs\MyCustomSearchFolderList.ini
Sample contents of a CustomSearchIniFile: 1=999>>>D:\Temp\Ftest 2=25>>>E:\MyDownloads\Audible>*>tv
The line should begin with #= The next number is the score for items found in this directory, followed by >>> Then comes the actual full path to the directory to search If you want to specify a modifier keyword to use, add >*> followed by the modifier keyword. The easiest way to understand the format is to add a search folder in the options as you want it and then examine the normal FindAndRunRobot.ini file to see how the format is saved.
