When the program is started for the first time (or if it finds itself missing a configuration file), Super Happy Find and Run Robot will initialize itself with default values which should work well for you with no modification.
First, check your system tray (the string of icons on the bottom right of your screen to the left of your system clock). If you do not see a little man in a blue circle, then the Super Happy Find and Run Robot Hotkey Tray Utility is not currently running - start it from the Start Menu. If you decide that you like this utility you can configure it to start with Windows from its main Options page.
Basic Use:
| 1. | Press the Pause/Break key on the upper right of your keyboard to start Super Happy Find and Run Robot. |
| 2. | Start typing the name of the application you want to run. |
| 3. | As you type, you'll see the results of an ongoing search through your start menu (or other directories you have marked for search). |
| 4. | The top best guesses for what you are looking for are shown in the list. You can at anytime revise your search, there's no need to wait for the seach to complete. |
| 5. | If and when you see the application you are looking for, press the key associated with that application to launch it, closing Super Happy Find and Run Robot in the process. |
