  • Thursday April 25, 2024, 7:33 am
Last post Author Topic: List all subfolders on multiple drives to text of csv  (Read 21382 times)
dcwul62
  • Joined in 2013
Re: List all subfolders on multiple drives to text of csv
« Reply #25 on: September 02, 2013, 02:14 AM »
later . . .
Matter solved: added root folders to library.
I can now generate a print from all folders using the library.
Have to confess, did not think of this before as I have never been using the library sofar.
For me the matter is solved.
To everybody: thank you all for thinking along with me!
@krksoft : maybe the issue I submitted in my earlier post, might help to further improve your program?
(if -of course- it is something that cannot be yet solved by the program already)
« Reply #26 on: September 02, 2013, 09:31 AM »
Matter solved[/b]: added root folders to library.
is that with directory opus? (I presume, but thought it better to check!)
krksoft
  • Joined in 2013
« Reply #27 on: September 02, 2013, 10:50 AM »
@dcwul62
The option you were looking for is on the "Behavior" page: "Limit display level".
This way you can count the size of all subfolders, but show only the parent ones (up to the level specified).
dcwul62
  • Joined in 2013
« Reply #28 on: September 03, 2013, 01:50 AM »
@tomos,
yes Sir! Directory Opus alright... :)
This is by far ... the best Windows Explorer replacement with an unbelievably lot of features and a very active forum.
It isn't cheap but worth every cent.
(No, I donot have shares, just a very enthousiastic user)
