Starting with version 1.09.01 Find and Run Robot comes with some default alias commands you can use.
Just type the alias name and then any optional arguments and select your choice from the menu (or hit enter for default item).
Remember you can add your own group aliaes and customize existing ones from the options page!
| • | dc - search the donationcoder.com forum |
| • | run - run a command on the windows path |
| • | email - start an email with default client |
| • | imdb - perform an internet search at the imdb website |
| • | paste - paste common info like date |
| • | define - search an online dictionary |
| • | search - do a web search with google pages, etc. |
| • | music - search for info on a band, etc. |
