Hotkey and Shortcut Summary
Top  Previous  Next
From Search Panel:
Ctrl+Alt+Enter
Launch ALL items in result list (useful with alias groups)
Ctrl+Left or Alt+Left, Ctrl+Backspace
Delete last word (or subdir) in search edit box
Tab or Ctrl+Right or Alt+Right
Autocomplete subdirectory in search edit box
Ctrl+Up and Ctrl+Down
Scroll through older searches
Alt+O
Open preferences
Alt+# , Ctrl+# , Ctrl+Alt+#
Launch items in different ways (see preferences)
Alt+Enter
Open file/folder in search edit box
Enter
Launch first item in resuilts
Escape
Select search edit text for overwrite, or close window if already selected (double click)
Function Key #
Launch item #
From Results Panel
Ctrl+C
Copy path of result to clipboard
Ctrl+R
Show right-click menu
Ctrl+T
Show custom statusbar buttons as a menu under cursor
