Alias Launching Tricks
Top  Previous  Next
You can now do some special stuff with aliases.
Customize the Appearance:
You can customize the text that gets displayed with each entry by prefacing custom text with |
For example:
Play Solitaire | c:\program files\games\solit.exe
File Window Options:
You can customize the way programs are launching by adding one of a few optional window modifiers to the very end of your file specification:
/winmax
/winmin
/winhid
/closeafter (force farr window to close after launching even if not set to by deafult)
/stayopen (dont close farr window after launching)
/icon=localfilename_from_aliasdir.ico (icon file must be in same dir as the source xml file defining the alias)
/hideifnoexist (hide the result if the file specified does not exist)
/runasadmin (run the file as admin)
For example:
Play Solitaire | c:\program files\games\solit.exe /WINMAX
You can now specify multiple programs to launch within one alias by separating them with ;;;
See also the #filecontents special virtual string to grab alias results from a file.
See also the help pages on Clipboard Tricks and Alias Action Keywords and Virtual Launch Strings..
